Go to Post I suggest that you don't discuss...sensitive issues about your team on this public forum. - Andy Baker [more]
Unread 05-03-2012, 08:04
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
pic: Hybrid overload!!!!
Unread 05-03-2012, 08:06
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: pic: Hybrid overload!!!!
Is there video of how this happened. I'm struggling to figure out how the balls didn't just knock each other off target on the way to the hoop.
I'm frankly impressed by how crazy that is.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 05-03-2012, 09:38
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
I was mostly watching ours until they started to get stuck, but part of it is due to how long the balls take to even start going down the chute once they're past the hoop rim. (Anyone who was worried about hoarding 6 balls at the Alliance Station in Teleop can probably relax.) There's actually a lot of time and room in there, though that's not to say it wasn't an amazingly executed Hybrid. We were all definitely impressed, and I've never seen a stadium go from cheering to booing so loudly and quickly.
Unread 05-03-2012, 10:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
This is hilarious and sad all at the same time. Sad because that's 5 hybrid balls that will only count as being scored in teleop.
Unread 05-03-2012, 10:08
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Actually the match was stopped following the conclusion of hybrid because the 'pokey pokey stick' wasn't able to unjam the balls without knocking some of them back onto the field.
-Dustin Benedict
Unread 05-03-2012, 12:29
Regardless, the rules are the ball has to make it through the counter in hybrid or it doesn't count. If it was only 3-4 balls and they could clear the jam without dumping balls on the field, you'd be out those 9-12 bonus points. It's an understandable rule from the GDC, but that situation in particular points out its potential difficulties.
Frankly, I'm surprised they even replayed the match. There's nothing in the rules covering what happens if the goals jam and if a team should be credited for all the balls past the rim or what. I could easily see the ruling coming down on the side of "If you lose some balls, oh well. Try to shoot slower next time."
Unread 05-03-2012, 12:36
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
The only video I've found so far unfortunately cuts away while all the shots were taking place and cuts right back to the balls being jammed and the ensuing chaos - http://www.youtube.com/watch?v=jldACuLN5i8#t=43m06s
We tried to time our autonomous shots so that they'd be about two seconds off from one another. In the previous rounds it had worked, but unfortunately there's always going to be a little bit of play in when the balls actually leave the robot.
I'm glad they decided to stop and replay the match, but it would not have surprised me if they let the match play through either.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 05-03-2012, 12:52
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Which rule says this? G39 says "hoop", not "counter". There appear to be two relevant Q&As; one from 1741 on 1/30 has this answer: "Any Basketball that enters the Hoop during the Hybrid period will receive the Hybrid bonus." The other (still pending) Q from 1114 concerns time of release.
Or is "hoop" defined somewhere to include the counter?
Mentor http://www.teamtitanium.org/
Unread 05-03-2012, 13:07
thefro526's Avatar
Mentor for Hire.
Actually, the ball just has to pass through the hoop.
[G39]
During Hybrid, an additional 3 point bonus will be added for each Basketball that passes completely through any Hoop.
In this case, three or four of the five balls lodged in the net had passed through the hoop. (The Number is debatable depending on your vantage point, I was immediately behind the red drivers station so this is the view that I'm most familiar with) They Technically should have counted in the Hybrid Period According to G39, but would not have since they would've passed through the counter during the teleop period.
As far as replaying the match, I believe it was the right call to make since the match continued on for at least 30 seconds with a clogged 3pt Hoop, severely handicapping the blue alliance.
-Dustin Benedict
Unread 06-03-2012, 22:14
There is video of this now on youtube, see how this autonomous mode played out here: http://youtu.be/m4Q0DMoOiVc
Unread 06-03-2012, 22:29
DonRotolo's Avatar
Back to humble
FRC #0832
Wow, just perfect timing on those first 2 balls, which then collided at the bottom of the net. Astounding.
Unread 06-03-2012, 23:49
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It's actually very easy/common for two balls to get stuck in the net.
There really ought to be a pause at the end of autonomous to let balls continue to pass through, or to unjam the basket so that the scoring is assessed correctly.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-03-2012, 08:39
Wow, what he said. Once I saw the video I know understand how easy it is for this to happen. I'm surprised it didtn't happen more.
Thank-you 294 & 67
Unread 07-03-2012, 09:09
Brandon Holley's Avatar
I agree, I see no reason not to. Just like in 06 where winning autonomous changed the match dramatically, taking a few seconds to make sure all the balls have passed through seems obvious.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
