Go to Post I think a lifetime of learning properly and then teaching others and inspiring the youth is more important to myself at least than being on the news for a couple seconds during a voice over. - Elgin Clock [more]
Unread 06-03-2012, 18:08
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
pic: Brakes.. Deploy!
Unread 06-03-2012, 18:10
Sb28000's Avatar
Sb28000 Sb28000 is offline
FRC #2656 (Quasics)
Sb28000 is on a distinguished road
Re: pic: Brakes.. Deploy!
Having a "brake" like that is an impressive idea! Is it pneumatic-powered, or driven by some motor? Also, why does 3451 have a blue bumper on half of its front side? I hope they built them sturdy enough to put up with that much weight applied to them!
Pittsburgh Regional Finalists 2010
Hoping to come back strong in 2012!
Unread 06-03-2012, 18:21
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
What extra functionality do those "brakes" give you over the typical servo w/ pawl into the gearbox?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 06-03-2012, 18:34
V_Chip's Avatar
Back in action.
AKA: Victor
Thank you!
The brakes are purely pneumatic.
Luckily 3451's bumpers were still intact, though we did leave an imprint.
Our brake system guarantees that once deployed, we do not move AT ALL. Say if an alliance member went to double balance with us, we usually offer to be the immobile member of the balancing act. Once on the bridge, we plant our brakes. If unbalanced and tipped in our direction, the brakes guarantee that we do not slip and roll off.
Our current configuration of plaction tread wheels may have plenty of grab on the carpet, but are quite slippery on lexan. The pneumatic brakes have an insured non-slip grip pad on the bottom. If the brakes are down, we're not going anywhere.
Here are some of the pictures we took at BAE GSR.
http://buzzrobotics.org/node/193
There is a close up of our deployed brakes.
Unread 06-03-2012, 23:14
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
This seems like a greeat way to get the coopertition bridge for 1 point if the clock is running out.
You guys looked great at gsr and I can't wait to play with you guys at CT again.
Also not sure on this but those might be in violation of the metal traction device on the field rule. I hope there is tread or something like that on the bottom.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 07-03-2012, 09:38
Sb28000's Avatar
FRC #2656 (Quasics)
My understanding of the rule regarding metal traction devices was about using a metal brush or "file card" (as I believe is the official "Manual" term for it) to gain a large amount of traction, and be nearly impossible to push. This is from memory, but I believe the rule began because a team used brushes somewhat similar to a wire brush used to clean grill racks, or wood files, that ultimately could cause damage to the field carpet. Perhaps someone who was around then, or has a more specific knowledge of it can back me up on that. But I don't believe the intent rule is against having metal at all in contact with the carpet - As long as it is smooth and not intentionally rough or desctructive, I'd imagine it could be used as skids, or in this case, a deployable brake.
Unread 07-03-2012, 09:53
V_Chip's Avatar
Back in action.
AKA: Victor
Thanks jblay! We're excited to compete at CT; so many great teams are in attendance.
We have rubber pads on the bottom of the brakes so that they are in compliance with the field rule. It took numerous traction/friction tests but we finally came across a material that suffices.
Unread 07-03-2012, 15:40
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I am excited to see another team with brakes -- especially one as good as 175.
Brakes win matches. They're almost the best thing a team could ask for when it comes to balancing bridges.
--Madison--
...down at the Ozdust!
Unread 07-03-2012, 16:12
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
After looking at your machine at BAE, I thought I spotted your brakes covered in black roughtop tread, am I right?
I only ask because you posted that the wheels are slippery on lexan but not on carpet, while the brake pads are grippy on both, and I had thought that the material on your brakes appeared to be the same material as the tread on your wheels.
From the testing I did, roughtop tread had a reasonable CoEF on the bridge, so part of me wants to say the reason you found you were sliding off the bridge before adding brakes wasn't because of the tread's CoEF, but because of the fact that your drivetrain PWMs were probably in coast mode, and you simply rolled off the bridge (your CIMs were backdriving).
Of course, I definitely could be wrong. I'd love an official 175 answer.
(09-12) - FRC 176 - Aces High
(13 - 14) - FRC 229 - Division By Zero
Clarkson University - 2016, Innovation and Entrepreneurship
Unread 08-03-2012, 03:06
pigpenguin's Avatar
pigpenguin pigpenguin is offline
Registered insane
AKA: Ethan Rooke
FRC #1160 (Titanium Robotics)
pigpenguin is an unknown quantity at this point
Yeah, that is correct. I was not around at the time but I went to a lecture thing (lack for a better term) and the mentor brought it up. The team would, from what I recall, pull its self along. It was immovable due to the iron wool getting mixed in with the carpet. Eventually some one did move it, how ever it took two robots and instead of the bot moving the carpet was ripped out after that year it became illegal. So yeah good times.
"Insanity isn't a plea its a way of life and here we are all one card short"
Unread 08-03-2012, 17:58
V_Chip's Avatar
Back in action.
AKA: Victor
Official 175 answer:
"It's top secret."
The PWMs are in fact in coast mode.
The tread used on the brakes is black roughtop that we've used for tread in past seasons. The material is a little harder than what is currently on the wheels.
