Go to Post Engineering is a career of continuous learning, acquiring new skills, and growth. - KenWittlief [more]
Unread 06-01-2003, 09:53
Kai Zhao Kai Zhao is offline
#0686 (Bovine Intervention)
Kai Zhao is on a distinguished road
Send a message via AIM to Kai Zhao
Suction Cups: How?
The manual allows for a team to use suction cups and to create a vacuum using the pump. How does one do this? Revese the electrical connections to the pump? Is there a "in" port of the pump where it'll create a vaccuum when running forward?
-Kai Zhao
Unread 06-01-2003, 10:31
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
DO NOT reverse the input to the pump! As for the in port, my team hasn't gotten our kit yet, so I haven't looked at an actual pump yet.
Anybody else?
--Rob
Unread 06-01-2003, 10:39
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Doesn't accelerating air over a hole creat a vacuum. That's how air planes fly. They accelerate air over the top of the wing which lowers the air pressure and creates lift. I know that if you take an air gun and blow arcoss the top of tub you can suck water up thru it so it should work with air as well. You can try it by taking a small piece of tubing and plug one end with your finger and the other end use an air gun to blow over the top NOT inside and see what happens
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 06-01-2003, 10:42
Unfortunately, a system like that would be a "custom pneumatics component", making it illegal.
Unread 06-01-2003, 10:53
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
The only way I see
I see only two ways to generate vacuum legally:
1. Use a cylinder to create a vacuum in the air tube and suction cup by driving the cylinder with another actuator (motor, etc.).
2. Use the suction cup itself. If you would use a bellows-style cup, you can press it down, seal it, and then pull up on the cup a bit and there would be a vacuum in the cup.
Neither of these uses would not give you very good vacuum, but vacuum none the less.
Andy B.
Unread 06-01-2003, 11:46
Let's have fun!
#1022 (ArcherGEeks)
I just read the part in the manual that states you can only use a cylinder to create a vacuum. Opps I guess that's what I get for being a slow reader.
James Grim
www.youthbotin.org
Unread 06-01-2003, 20:34
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
Question
My team also has had some trouble with the idea of suction cups. I belive you must use some kind of device to flatten the cup and the peel it up later.
pi is exactly 3
IM me at: zmstr265
Unread 06-01-2003, 22:21
Let's have fun!
#1022 (ArcherGEeks)
As stated above all you would have to do is take an air cylinder and don't hook it up to the air. use one of the port and hook it to your suction cup and pull or push the shaft and it will create a vacuum on the port.
James Grim
www.youthbotin.org
Unread 08-01-2003, 15:33
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Very little of a plane's lift comes from this, almost all of it comes from the angle of attack. Stick your hand out the window of your car, directly into the wind. Curve it, notice any difference? Now angle it up.
The only way I can think of to leagally create suction (good suction) is to use pnumatics to move a plunger inside a tube. If done right you shouldn't lose any pressure.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 08-01-2003, 16:14
Lisa Lisa is offline
#1159 (Ramona Rampage)
Lisa is an unknown quantity at this point
Send a message via AIM to Lisa
i thought suction cups were illegal.
Unread 08-01-2003, 20:43
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Greg
What you're talking about is the Bernoulli Effect. Basically, it means that as the speed of air increases, the density of the air decreases. In the case of an airplane, the curve of upper section of the wing causes the air to travel more quickly over the top than the bottom. This creates a lower air pressure on the top so the airplane lifts up.
Now, many modern planes use an "angle of attack." What this means is, that as you fly, depending on how much lift you want, you change the angle of the wing, which causes the curve "seen" by the air to change. This gives a change in the amount of lift.
Matt
Unread 09-01-2003, 15:18
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
The reason why you would use a suction cup is because with no air between the cup and your surface, there's no air pressure, and you get 14 pounds/square inch pressing down on your cup, increasing the force of friction. All you need is a large suction cup and use a pneumatic cylinder to press the air out. As for why airplanes fly, it's mostly conservation of momentum with a little Bernoulli, according to my competent physics teacher. I'd use ansi art to illustrate but I suck at it. Basically, air flows into the turned wing and exerts a force on it up. As air travels down the back of a curved wing, again, conservation of momentum the wing must move up to have no momentum gain.
0N3 1337 PR0G|24MM1N6 N1NJ4
Unread 09-01-2003, 15:38
frumious frumious is offline
frumious is an unknown quantity at this point
Send a message via ICQ to frumious Send a message via AIM to frumious Send a message via Yahoo to frumious
I'm fairly sure using the bernoulli principle would fall under the 'custom pneumatic components' section, anyway. I think the only way to make a vacuum legally involves actuating one pneumatic cylinder with another, creating a vacuum air connection of the cylinder being moved. If you attach this to a decent suction cup, you should be able to form a vacuum between that and any surface.
Tyson
Unread 09-01-2003, 16:19
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
plunger?
think of how a plunger works / for a couple of bucks you have an inexpensive suction cup you could prototype with.
Unread 09-01-2003, 17:28
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
It shouldn't take that much pressure to make a suction cup go down. It all depends on the material of the cup itself. I would think a normal automotive suction cup from msc would be the way to go. Those don't look like they were designed to be used by a vacuum pump. Plus if what I'm guessing is true these suction cups can have 170pounds of suction.
Best use of suction cups in Galieo? Spikey Championship Event 3 21-04-2003 20:36
pic: Team 870 Suction Cups CD47-Bot Robot Showcase 45 29-03-2003 22:48
Q&A Discuss: Suction Cups CD47-Bot Extra Discussion 14 27-03-2003 18:04
Image Discuss: Our anchor is more powerful than you bot CD47-Bot Robot Showcase 31 22-02-2003 21:00
Suction Cups Lauren Hafford General Forum 4 06-01-2003 00:01
