Go to Post Curse those filthy wrench-swinging rivet-popping screw-driving hammer-smashing mechanical barbarians. Hand over the robot to the programmers! - cjl2625 [more]
Unread 07-03-2012, 21:18
Re: Auto Code NOT Running (as expected)
Originally Posted by kws4000 View Post
On a similar note, what are the X and Z axis on the Kinect? ie which bodily function does what? We have Y good! (the arms)
The default gestures in the FRC Kinect Server do not map anything to the X or Z axis, they always return 0. Note that Alan's point about loops also applies to Kinect code. Your Kinect code must be in a loop to read new values from the Kinect and update motors with them.
