Go to Post You do know that totes are supposed to go through the chute right? Not humans? - themccannman [more]
Unread 07-03-2012, 16:17
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Question Auto Code NOT Running (as expected)
Here's a screen capture of auto code.
As it is supposed to run, shooter starts immediatly.
After 3 second wait, conveyor2 starts.
After 7.5 seconds, conveyor1 starts.
All run until end of Auto.
BUT all turn on at beginning of Auto at the same time.
I know in previous years we could get the time-elapsed for the auto-period and use that to control the operations. Now, ????
Name:	2405 AUTO 2012 Comp1.JPG
Unread 07-03-2012, 16:27
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Auto Code NOT Running (as expected)
The problem is with your usage of the millisecond timer. It has no reference time (i.e. millisecond zero is just an arbitrary point in time). Therefore, you have to measure the change in timer value, which will give you milliseconds elapsed. Try the attached snippet instead.
Unread 07-03-2012, 19:58
kws4000's Avatar
AKA: Krazy Karl
That would likely do the trick, but it's now commented out because (in theory) the Kinect should be able to replace it!
On a similar note, what are the X and Z axis on the Kinect? ie which bodily function does what? We have Y good! (the arms)
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 07-03-2012, 21:10
Autonomous Independent is only called once, when autonomous mode begins, and runs until it's done (or until it's aborted by the framework when teleop mode begins). It's not like Teleop, which gets called every time new data arrives from the Driver Station and needs to finish quickly. If you want to do different things at different times, you'll have to put the code that reads the time and decides what to do inside a while loop.
But since you're just doing a sequence of events with delays between them, you can use a Flat Sequence structure very effectively. See the attached code snippet. (You can put it inside a case structure to control whether or not it runs, based on the joystick throttle the way you did it in your code.)
Unread 07-03-2012, 21:18
The default gestures in the FRC Kinect Server do not map anything to the X or Z axis, they always return 0. Note that Alan's point about loops also applies to Kinect code. Your Kinect code must be in a loop to read new values from the Kinect and update motors with them.
Unread 07-03-2012, 21:39
kws4000's Avatar
AKA: Krazy Karl
Lana? Yeah that is EXACTLY what we were looking at.
Shucks, that'll take more thinking...thinking always gets me in trouble....
So just put everything in one giant loop w/ a FALSE wired to the Terminator? On second thought, that may be a bad idea... I have bad memories of that angry little doggie...
Mentoring:
Unread 07-03-2012, 21:43
Heh, that should have said Alan.
Yes, a big while loop with false on the terminator should work just fine. Make sure to put a Wait Ms VI in there, 20 to 50ms should work well.
Unread 07-03-2012, 21:53
kws4000's Avatar
AKA: Krazy Karl
Okay, but any infinite loops are on your tab next week, I've already footed the bill my team gives the programmers long enough!
Mentoring:
Unread 07-03-2012, 21:58
As long as you have not modified Robot Main, the Autonomous Independent VI will be automatically terminated when the robot changes modes, regardless of whether it is currently "caught" in a loop or not.
Unread 07-03-2012, 22:16
kws4000's Avatar
AKA: Krazy Karl
Would passing Ultrasonic and Joystick data to the Dashboard inside Robot Main qualify as "modification"?
Mentoring:
Unread 07-03-2012, 22:40
Nope, that should be fine.
Unread 12-03-2012, 16:45
kws4000's Avatar
AKA: Krazy Karl
Question Re: Auto Code NOT Running (as expected)
Annnddddddddd, (drum roll please)
It doesn't work. Error #-44061 at Leftand Right Motors, standard loop starvation code. The joystick z-throttle selector works.
We have a loop around all Auto Code, with a Wait in there of 20, and tried again w/ 50. Loop starvation every time!
Also, sending kinect2 yaxis back to dashboard. Always sends "0", even when doing the floppy chicken!
So therefore, is it some error in setting up the Kinect, or can the robot not reliabley interpret the Kinect data?
Mentoring:
Unread 12-03-2012, 16:48
If you run the default dashboard, does the Kinect "green man" and Y-axis data show up?
Unread 12-03-2012, 16:51
kws4000's Avatar
AKA: Krazy Karl
yep. The little bars work fine, but the robot won't reliably read the kinect and sentd that data back to a custom readout, and yes the indicator works properly just like the other 2 windows we have right above it.
I think if the dashboard can finally get the proper data, then the robot auto code will work fine.
Mentoring:
Unread 12-03-2012, 16:56
The output of your feedback node in that snippet never changes.
