Go to Post Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it. - Isaac501 [more]
Unread 08-03-2012, 00:23
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Predictions Week 2: March Madness
Originally Posted by SuperNerd256 View Post
Odd. SVR is always with the screen to the side, so both teams can see. I always thought it was the same way everywhere.
Most are, but not all venues can accommodate this. I've seen it mostly in regionals that are held on convention center floors or large gyms, rather than in stadiums. Chesapeake in 2009 and DC in 2011 had the screen behind the Red alliance driver stations, in order to have enough room to put the field between two sets of bleachers and allow people to walk by. If I recall, Connecticut has done it this way in the past as well.
The advantage of the setup is that you get seating on either long side of the field, rather than just one side and seats behind both driver stations. It makes for a much better view for a larger portion of the audience, and more of the audience has a good view of the screen too, due to the viewing angle.
I have seen a small screen and projector setup at some events so that both driver stations have a score screen they can look at. Hopefully the events that are using this arrangement this year have taken that into account as well.
Unread 08-03-2012, 00:35
commodoredl commodoredl is offline
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
At FLR, the screen is behind the Red Alliance (so the Blue Alliance can look directly at it). However, to fix any advantages, in the last few years the corner stations of the Red Alliance station had LCD screens installed with the live feed to allow coaches to still view the real time scoring. I'd expect FLR to have those screens again this year.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 08-03-2012, 07:21
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Originally Posted by Looking Forward View Post
After the Poofs nabbed their championship last year, 233 is left as arguably the most successful team without an FRC championship. Despite the quantity of banners they've obtained from this regional, Pink hasn't always had their best event in Orlando. Their success is driven by constant improvement and work, but hiccups and technical issues have plagued them in the past at their opening event. Can 233 come out of the gate roaring, or will they need time to get it into gear?
Nothing argueable about it. They are overdue as the only team to go to Einstein 4 times and not have a Championship banner. After that its gets muddy with the 3 teams that have gone 3 times, but 968 has had the most success of late.
Thank-you 294 & 67
www.bobcatrobotics.org
