Go to Post 118 embodies everything this entire program is supposed to be about: INSPIRATION. Respect that. Acknowledge that. Support that. - barn34 [more]
Unread 08-03-2012, 09:20
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Team update 3/6/2012
Originally Posted by martin417 View Post
Except that was not stated intent of the GDC. The Bridge was designed so that balls could be removed by pushing the bridge down on the opposite side. The bridge did not function as designed and published at the beginning of the season. The change was made to try to correct this flaw. Had the GDC not published the ball deflector as a means of ball clearing, both in the field drawings and the Field tour video, you might have a point.
What I saw at both the Week 0 and the Week 1 was balls that the ball deflector worked on balls that were stuck reasonably far under the bridge, as depicted in the field tour video. However, balls that were near the very end of the ramp would not roll out, as might be reasonably expected because the lexan is supposed to be taped down by its edge. Even with the change is still impossible to tip out balls that are only partly under the bridge.
It might be that some fields (and even different bridges on the same field) were setup slightly differently and therefore behaved differently and that you and I merely have different observations.
