Re: Testing Camera Tracking while in the pits
When your DAP1522 is in Bridge mode is not broadcasting a signal. There should be no issue with plugging things in as Jared described and running in the pits.
thanks guys.
Another alternative is to simple bring a small switch with you. Unplug the Bridge, connect the switch in it's place and it should be smooth as silk and ZERO issues with the Bridge being on.
And BTW, the Bridge still does broadcast in Bridge mode, so don't be caught unaware. |
It's my understanding that the Bridge will be receiving a signal, no doubt. But I also believe, and please correct me if I'm wrong, it will still generate a signal as part of it's process to "associate" with a network. Thus, it still broadcasts. The only way I know of to completely silence the Bridge is to power it off. Now whether that is truly necessary in the pits is debatable. |
