Go to Post And we drafted without computers...forget the calculators...we used slide rules...the punchcards piled up so high we needed more office space...and we programmed in three feet of snow...up hill...both ways - Rich Kressly [more]
Unread 08-03-2012, 12:54
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Unhappy Unable to run cRIO with cRIO2 program
Dear CD,
I have been running FRC3548 team robot code on the cRIO2 successfully for some time and am finally getting around to program the original cRIO because the cRIO2 is headed for the robot this weekend at Waterford, MI.
I was success in re-imaging the cRIO from v28 to v43. I was able to deploy and execute the Run at startup command and hit the reboot cRIO as expected.
However, on the driver station the top light goes green but not the bottom light - it remains red (sorry not looking at it right now for proper description).
Any suggestions on how to proceed? Same Labview code, same bench, same ca bles, same Labview IO modules - etc. Only thing different is cRIO.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
