Go to Post I need to start sleeping now to make up for build season - Kingofl337 [more]
Unread 08-03-2012, 18:46
helpme helpme is offline
None #3662
helpme is an unknown quantity at this point
questions
bumper-
is it legal to use velcro as a back up along with bolts or another sturdy connector ?
pit-
are we aloud to use projectors and/or music in the pits?
Unread 08-03-2012, 19:11
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: questions
I don't think you really have much space in the pit for a projector. You should not have music in the pits, they are already loud enough.
Unread 08-03-2012, 19:15
None #3662
Re: questions
yeah there is not much space. but is there any rules prohibiting it?
Unread 08-03-2012, 19:16
Re: questions
With regards to the bumpers, I think that would be acceptable. Final determination would lie with the inspectors at your event, however.
For the pit, the projector would be OK if it was used in such a way that it didn't blind people. (i.e., short-range, aimed at a screen) A TV or laptop would probably be better. But the music...
If it's loud music, you will be asked to turn it down/off; after two warnings, you can bid the music (and possibly your pit power) goodbye. (Administrative Manual 4.15, 10th bullet). The music can (read: will) interfere with your team and other teams hearing the announcements. Also note that the pits are pretty noisy as they are: work, conversation, noise coming from the arena, pit announcements, cheering as teams come back from events, and (hopefully not) yells of "ROBOT!!!!!" as teams move their robots around.
Unread 08-03-2012, 19:20
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Re: questions
This is interesting. [R28] specifies that "bumpers must attach to the Frame Perimeter of the Robot with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with Velcro)". I think the idea is that teams may not use only velcro because it is not robust, but the statement also seems to ban Velcro totally. I don't think this was the intent, which means....
Q&A time!
Also, is there a reason why you need Velcro in addition to whatever you have? If your standard mounting system is weak enough that it needs Velcro, then Velcro will not really help.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
Unread 08-03-2012, 20:00
1986titans's Avatar
1986titans 1986titans is offline
1986: It's a team #, not a year.
AKA: Paul Shackelford
FRC #1986 (Team Titanium)
1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future
Re: questions
I had the same thought. If bolts can't hold your bumpers on, how will Velcro?
As for the projector, feel free to bring one, as I haven't seen anything in the rules to the contrary. Realize that you probably won't be allowed to project on stuff outside of your pit, and limiting the projection area to inside your pit usually means that you could be better off having a small TV or laptop sitting out showing whatever you want to have projected.
That being said, there are still some cool uses for projectors. 1730 uses a projector for their pit banner.
Paul Shackelford - http://www.archkc.com/
Kansas State University - Electrical Engineering '15
Team Titanium - Lee's Summit West HS - FRC 1986 - Student [2009-2011] - Captain [2011] - College Mentor [2012]
Unread 08-03-2012, 20:58
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: questions
Originally Posted by helpme View Post
pit-
Seen this done by 935 at GKC in the past. Paired with a professional looking pit structure you have a very nice pit.
IMHO- Music is not ok, but commentary from the matches, or from a different video is ok. ie. Noise that has a specific purpose, not just "background noise" like music often is. Keep in mind, you may be asked by officials to turn it off, but we haven't had a problem with that except at championships.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 09-03-2012, 00:51
None #3662
Re: questions
we have found that with bolts as fasteners the bumpers stay on but the tend to wiggle around a bit we were hoping to use industrial Velcro to keep them from making any movement.
Unread 09-03-2012, 08:30
Nate Laverdure's Avatar
FRC #2363
Re: questions
This probably calls for more bolted connections, farther apart from one another. Could you provide a picture?
Unread 09-03-2012, 11:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: questions
I am not sure what Velcro will buy you. Since rule [28] specifically says not Velcro, I would not represent it to the inspectors as part of your primary attachment system. ie The other fasteners would have to fully support the bumpers to the requirement of the rules.
Watching week one videos, I saw a lot of poorly attached bumpers though.
We used Velcro one year to hold down the battery. It work really well, but is was a pain to change batteries. It took a pry bar to remove the battery.
