Go to Post I don't think FIRST is the reason for following rules, being respectful, etc. We should do that anyway. - Dan Zollman [more]
Unread 08-03-2012, 13:41
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
48 point autonomous
Ok, so after the Israeli regional is over, i now realize it is possible in theory.
Iv'e seen team 1690 scoring 4 balls in auto, 2 of them were their own, and 2 more were collected from the coopertition bridge and shot. Their bot has a design that allows them to drive to the bridge, touch it, collect the balls from the backside of the bot and shoot it from the front.
If they played with 2 teams who score 2 balls each in that match, we would have had a 48 point hybrid (how's that, car neck).
They only did the 4 balls thing once i think, but managed to get 3 balls the same way a couple of times more.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 08-03-2012, 14:22
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 48 point autonomous
I think 54 points in autonomous is doable if the first bot to shoot is a catapult that's pre-charged. At one point I thought 10 balls was possible in the high goal, but after seeing the necessary timing requirements between balls so they don't get stuck I no longer think it's possible for the 10th ball to pass the sensor before the buzzer.
Of course, there's always the middle goals. 20 points from 2 partners, 12 from the 3rd. 2 of the partners go to different bridges for the remaining 4 balls (maybe more). If the middle bridge bot goes for the high goal and the side bridge bot goes for the middle, that's another 22 points. 54 easy points, or 56 if properly timed -- potentially more if there are more balls on the middle bridge. On top of that, the opposing alliance has to scramble to get enough balls back onto the field to get to the 2 balls/player requirement, so there's 2-4 balls available in tele-op before defense is even a factor. A good catapult (primary), a consistent layup bot, and a good off-centered key scorer are perfect for this setup. With 2 bridge stabilization devices on the alliance, it'll be very hard to overcome except by a similar alliance.
I doubt we'll see this until a district championship or St Louis though.
GitHub
Unread 08-03-2012, 14:42
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Well 973's latest facebook post:
‎6 ball auton is working.... lets hope it works on the comp bot, and that the refs see the rules the way we do....
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 08-03-2012, 18:12
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
From what I have heard over the past couple of days (Adam has been up at shop all week making sure we have modifications for LA), there are certain circumstances where it will work and if the Refs do rule it legal we will be set for it come LA. I should be heading up this weekend to see for myself and if all holds true, it should be another benefit the robot will have this year.
Now you need to remember that is only 36 points being scored.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 08-03-2012, 19:25
Brandon Ha Brandon Ha is offline
FRC #0302 (Dragons)
Team Role: Electrical
Brandon Ha is on a distinguished road
It seems easily possible to do 36 with the ones given to teams, albeit two teams had non funcioning autons and the third was just amazing at shooting, 3322 props. But to say that two teams would travel to the bridges and tip and shoot would only, most likely, happen in nationals because of the caliber of teams there. Theorectically anything is possible and technically someone could do it but it has a higher probability of occuring at nationals.
Unread 08-03-2012, 20:02
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
[G39]
During Hybrid, an additional 3 point bonus will be added for each Basketball that passes completely through any Hoop.
I still don't see how they can say a ball has to pass the sensor during hybrid for it to count in hybrid. 3 points can be the difference between a win and a loss in a good match.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 08-03-2012, 20:40
Andrew Lawrence
Posts: n/a
Yes! Prove Car Neck wrong!
Unread 08-03-2012, 21:36
AsianPersuasion's Avatar
AsianPersuasion AsianPersuasion is offline
AKA: Justin M.
FRC #0240 (Tempest)
AsianPersuasion is an unknown quantity at this point
If you look on youtube, you can find an amazing autonomous by team 3322, eagle imperiums. Search "Kettering 2012 finals frc" and load final match 01. it's great.
Unread 09-03-2012, 10:29
JesseK's Avatar
FRC #1885 (ILITE)
Any 2-sided-intake bot can easily get a 36 point autonomous just by dead reckoning and running everything. The onus is on the partners to get the timing correct
GitHub
