Go to Post Our prototypes are good and running, now just need to do some magic to transform all that wood to aluminum. :eek: - FIRSTMa2104 [more]
Unread 08-03-2012, 08:59
Andrew Lawrence
Posts: n/a
What is wrong? [HELP]
Our final, final robot weighs around 85 pounds, WITH the electronics. For years, 256 has had to swiss cheese our robots to make the legal and under the weight limit, however this year is different, and we didn't do it on purpose.
I don't think we forgot anything:
-Sturdy drivetrain
-sturdy frame
-articulating ball shooter
-accurate bridge actuator mechanism
-very well working ball intake
-very well working ball elevator
What I don't get is how we have managed to come under weight. It is our first time making a custom chassis and superstructure, but I didn't think that could loose us so much. I'm afraid something on our robot is under-built, and too weak, but everything is stronger than me in some cases.
What should I do?
Our scale works perfectly, and since we were also unsure, we used another one we never used before and got the same weight
Unread 08-03-2012, 09:05
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: What is wrong? [HELP]
I would invest in a new scale.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
Strap on 33 lbs. An underweight robot makes it difficult to balance with other teams on the coopertition bridge.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 08-03-2012, 09:08
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Stop bragging about being under weight.
Seriously though not knowing the details of what your robot looks/performs like it's hard to answer that question. I can list possible places you could have missed but I need more info.
Is your frame too thin/weak?
Do you have normally have pnumatics but not this year?
Are there fewer sensors?
Did you use a different drive system than normal?
Is your robot really short?
did you use just the smallest motors in the lkit?
Are you lacking protection/shielding around your electronics to prevent balls from sticking in your robot?
Is your robot not the full 28"x38" that you're used to?
Just some stuff I though of quick.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 08-03-2012, 09:10
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
ASAP, weigh it on a scale that you've never seen before, just to cover your bases.
Beyond that, add weight as others have said. That or make yourself the robot that aids the balancing while popping the last shot off.
And nothing wrong with being that far under.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 08-03-2012, 09:13
Andrew Lawrence
Posts: n/a
No, it's sturdy
Actually....yes! Come to think of it, we lack pneumatics this year
Just about the same
4WD wide instead of a 6WD long
Not really.
Nope.
Right now, yes, but the one we built is already factored into the weight
it is, although it's a welded frame, so a lot of it is opened up.
Thanks for the help! I'm thinking it's the lack of pneumatics and lighter frame, though I never thought the combination of the two would loose us 30 pounds..
Nor my new problem: What to do with those 30 pounds? The bottom of our robot is mostly hollow to allow our intake to pick up from both sides, so it's hard to put things places.
Unread 08-03-2012, 09:30
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Have your programmer add more 1's into the program an remove as much of the 0's as possible
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 08-03-2012, 10:18
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
At our pre-bag scrimmage, without our shooter on, but WITH our bumpers, our robot was 81lbs! It was VERY hard to control.
With the shooter (and no bumpers), it should be around 90, 95. Still light. I think not using pneumatics is a big deal for us.
Unread 08-03-2012, 10:24
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We managed to avoid that problem by welding up a nice 27 pound steel frame for the bottom of the robot. And we have about 10 lbs of pneumatics, too.
One rookie Tucson team we've been following has a really light robot like that, they came up with a neat design for their sheet metal sponsor to make, and their robot is somewhere around 85 lbs.
Since the bridge causes short wide robots some issues, especially when there are balls under the end of the bridge, you might see if there is some heavy thing you could add to the bottom that would make bridge climbing easier, and flipping less likely. We're looking into this for our robot.
Unread 08-03-2012, 10:28
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
There was a team at kc that put a steel plate into their robot chassis which helped them not become so tipsy during comp it worked very well for them. Bridge balancing does become harder without some "good weight"
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 08-03-2012, 11:54
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
This sounds like a great opportunity to try to lower and center your CG. We did something very similar weighed in at 93lbs at bag, so during un-bag we added steel plate to beef up our frame in the 4 corners as low as possible. Moving weight out the the edge of the frame helps improve your stability much like a tightrope walker with a long weighted pole.
I'd agree it's beneficial to be closer to 120-lbs to ease balancing multiple robots.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 08-03-2012, 16:03
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I put a picture of this steel plate on flickr, and it is linked in the robot showcase thread I just created:
http://www.chiefdelphi.com/forums/sh...hreadid=104366
Unread 08-03-2012, 20:38
Andrew Lawrence
Posts: n/a
Thanks all for your help! I really appreciate it. An underweight robot is just as bad as an over weight one, so I'm glad we'll be able to beef up our machine.
We decided to use the extra weight to lower and center our CG, and well as make our robot look really cool.
Unread 08-03-2012, 23:16
Andrew Lawrence
Posts: n/a
Originally Posted by Garret View Post
I would still check on another scale if at all possible, its never fun to go in thinking you are underweight only to find out on day 1 of the tournament that your scale was bad and way off. I know from experience this year...
We've tested it on a total of 3 different scales as of today. All 3 gave us the exact same measurement, +/- a .5 lb.
Unread 09-03-2012, 00:25
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Originally Posted by SuperNerd256 View Post
Our final, final robot weighs around 85 pounds, WITH the electronics. [/b]
Not sure if I told you already, but we are about 15 under. We are definitely gonna bring some thick steel to attach on Thursday.
As for where, you could attach it to the very bottom of your robot, sort of like a baseplate. This should not change much, as it would be low enough to allow balls to pass over without any problem.
You could always just put on one of those half-freshmen that lay around after accidents...
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
