#12
Re: Tech Inspection
970K indicates a potential problem that needs tracked down. Can be EXTREMELY difficult to trace.. better done BEFORE competition starts. I've spent half day helping a team disconnecting everything until culprit was isolated.. a good team too.. 207 from LA!! When doing RESISTANCE test: swap probe leads to check BOTH polarities. Shorts often exhibit diode behavior due to intervening multi semiconductor paths. The Lowest R reading rules and must be >10K to pass.. BUT--> Anything around 100K is a problem in spite of 10k spec. if you don't want sporatic random robot resets during competition!! Good robots will read infinity!! there should be nothing conductive at all to chassis. >2M (Harbor Freight) to >40M ohm (industrial grade) Do you use a 1M potentiometer by chance?? a bit high to use for position or most sensor feedback applics, just a thought RS-775 tab to case shorts are usually around 1 ohm AT motor .. however when routed thru H-bridge of Jag's or Victors can show up as ~100k.. I believe Team 207's last yr was 200-300k & asymmetrical when ohmmeter leads were swapped.. they had 2 case to tab, 775 shorts! And all new ones left in Spare Parts were shorted! (6) GP: Attention teams possessing good 775's & NOT using them PLEASE bring unused RS-775's to competition: Pitt announce they're available To troubleshoot.. Remove both leads from one motor / device at a time until R changes .. use lower of swapped values as it is more solid (higher reverse resistances often waver around a bit making ya crazy) Good luck... |
