Go to Post ...can I play a computer game during a competition, while i'm suppposed to operate the robot? - Gal Longin [more]
Unread 09-03-2012, 10:38
Team1605 Team1605 is offline
FRC #1605
Team1605 is an unknown quantity at this point
Need serious help with coding!!
How can i program the part of my robot that will tilt the bridge towards me. i want it to go tilt forward then back. i am coding in netbeans (java).
Unread 11-03-2012, 14:12
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Need serious help with coding!!
The answer to your question can be affected by a lot of things:
  • Which of the many different possible bridge tipping mechanisms are you using?
  • Is it controlled by a Spike, or a speed controller? If the latter, Victor or Jaguar?
  • Are you using the IterativeRobot template, or a Command-based one?
  • Do you want it to respond to user input? If so, should it be button-controlled or joystick controlled? Do you want a button to toggle it?
  • Are there any limit switches involved?
I don't want to give you bad advice, so a little more clarity would be helpful.
Unread 12-03-2012, 17:56
Jmgiacone's Avatar
Jmgiacone Jmgiacone is offline
FRC #2115 (NightMares)
Jmgiacone is an unknown quantity at this point
A great tool that really helped me a lot was the getting started guide(here), and the FRC Programming Cookbook(here). These are both chocked full of great resources, examples, and explanations and are a great way to overcome problems.
Unread 12-03-2012, 21:39
abrightwell abrightwell is offline
Lead Software Engineer
FRC #0342 (Burning Magnetos)
abrightwell is an unknown quantity at this point
+1
Also, do you have code that already exists that you would like for us to take a look over/review for you?
Unread 19-03-2012, 10:29
FRC #1605
i am using jaguars(speedcontrollers) i have something like ahand with wheels that i want to tilt. i want a button to toggle it one button tilts forward other button makes it goes backwards
and yes i have code i will post it that too
Unread 19-03-2012, 10:38
How is the mechanism supposed to know when to stop, in each direction, after you press each toggle button? i.e. are you using limit switches, or a potentiometer, or an encoder, or something else?
Unread 19-03-2012, 15:31
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
a basic code would be
if(joystick.getRawButton(4)
     jaguar.set(1);
else if(joystick.getRawButton(5)
     jaguar.set(-1);
else
     jaguar.set(0);
Unread 19-03-2012, 15:41
Sconrad Sconrad is offline
AKA: Connor Young
FRC #0122 (NASA Knights)
Sconrad is an unknown quantity at this point
     jaguar.set(1);
     jaguar.set(-1);
else
     jaguar.set(0);
Note: This will not create a toggle effect. If 4 is pressed, the motor will go forward and if 5 is pressed the motor will go in reverse, but it will not continue to go in that direction if you let go of the button. However, this is a good, simple solution to the problem you are facing. One thing to note about how this code will perform, if both buttons are pressed, the jaguar will go forward. One way to fix this is to replace the first line with
if(joystick.getRawButton(4) && !joystick.getRawButton(5))
It is a little bit longer, but will protect you from accidentally going in the wrong direction should you hit both buttons in the heat of competition. In order to have a true toggle effect, you will probably need a limit switch or potentiometer or other sensor to tell you when you are done going up or done going down. Hope this helps!
Unread 19-03-2012, 16:16
In addition to the above, the other issue you will have to deal with is: How are you going to hold the "tilted hand with wheels" in place once it has reached the desired position?
