Go to Post FIRST truly isnt about building robots, but allowing yourself to reach higher and farther than you ever could. - Brandon Holley [more]
Unread 09-03-2012, 11:49
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
[DFTF] Anderson Powerpole Connectors...
This is part of a series of posts called Drinking From The Firehose on getting Dr Joe back up to speed on All Things FIRST.
Today's topic: Anderson Powerpole Connectors
Honestly, I love 'em. My experience is that once you learn how to use them correctly (crimp, install, join into blocks, tie wrap), they are a very reliable and robust method to make connections on a FIRST robot.
Others have other ideas... ...some are violently opposed to using them.
What is the collective wisdom of the folks on CD as to Anderson Powerpole connectors?
Pros, Cons, Pro Tips, pictures, anecdotes... ...give 'em to me.
If you are against them please propose your alternatives.
Joe J.
Team #88, TJ2
Unread 09-03-2012, 11:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: [DFTF] Anderson Powerpole Connectors...
I think they're great....if indeed you need them. We hardly ever need to disconnect motors and stuff on our FRC robots, so we generally just hardwire it all together.
But I've used them on the underwater robot power systems, where we only use about ten amps, they are very handy for that, we have them on the battery boxes, solar panels, and ROVs.
Unread 09-03-2012, 12:01
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
422 discovered them a couple years ago and now use them whenever we get a chance(at least twice as often as necessary). They're excellent for making modular systems and spares since it cuts down on replacement time. One challenge we had with putting them into blocks as connectors is that if you don't think ahead and make sure they look different it can be very easy to connect the wrong things together when plugging things in in a rush.
KK4KQO
http://voltair.us
Unread 09-03-2012, 12:02
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by squirrel View Post
<snip>
<snip>
I must be doing it wrong then, because I have never built a robot that I haven't had to take apart many many times ;-)
Joe J.
Team #88, TJ2
Unread 09-03-2012, 12:08
We use them to interface our drivebase to the superstructure, which typically mounts with 4 bolts. We solder the connectors onto the wire rather than crimping, which has worked well.
Unread 09-03-2012, 12:12
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
I've heard a lot of good things about these and we tried to use them but we had some problems. Unfortunately I do not have the correct P/N's of the components we used right now but here is what I think we have:
45A Connector Kit: http://www.powerwerx.com/anderson-po...pole-sets.html
30A Connector Kit: http://www.powerwerx.com/anderson-po...pole-sets.html
Crimp Tool: http://www.westmountainradio.com/pro...ts_id=PWRcrimp
We followed the instructions as best as we could from Powerwerx, Westmountain and on here but all of the connections we made were very loose, i.e. after crimping the terminal on the wire and then inserting into the connector very little force was required to pull out the connector. We spent quite a bit of time trying to get this figured out, including talking to Powerwerx Tech Support (who admonished us for not using their Crimping Tool) to no avail. I believe we finally got one to work after spending a lot of time on manipulating the terminal with a needle-nose pliers to make it sit into the connector correctly.
I'm sure that the problem we had was that we weren't doing it correctly, somehow. We ended up not using them at all and we haven't had any connections go out so far this season (due to having direct connections between devices instead of splicing wire together) so we haven't looked back yet. I'm sure if we had someone knowledgable around to show us how to use these we would use them in the future (and we do, some nearby teams use them, we've just been too busy with other things).
Unread 09-03-2012, 12:24
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Love 'em too.
In 2010, we wanted to be able to disconnect our electronics board entirely from the rest of the robot. Some 12-gauge quick-disconnect connectors would not crimp properly. We got some automotive alternator connectors that claimed to handle 50 amps, even though the wires looked a bit small, but they were COTS connectors, so we wired them up. We drove the robot the night before ship. A few minutes in, the wires that came with the connectors began smoking. We removed the electronics board shipped the robot with wires still warm.
Before our first regional, one of our mentors went to an amateur radio store and got us a ratchet crimper and a set of 40A Anderson Powerpole connectors, which we promptly crimped onto the leads from our electronics board. When we got to the regional, we crimped the connectors onto the motor leads. Worked well.
Now we use them on anything that might have to be disconnected, right down to cRIO and breakout power.
Where do other teams buy theirs? We bought ours from PowerWerx last year but then found them on McMaster-Carr this year and then lumped them in with another order.
lpickett's Avatar
lpickett lpickett is offline
Linda Pickett
FRC #1730 (Team Driven)
lpickett is a jewel in the roughlpickett is a jewel in the roughlpickett is a jewel in the rough
I agree that soldering is the way to go. I am an electrician and soldering these connectors is more reliable than crimping. You can crimp, but make sure it is with the proper tools and correct parts. You might also use colored heat shrink to ensure a good coverage on the soldered joint. It gives a little more strength to the connection.
Unread 09-03-2012, 12:28
Do uncrimped connectors fit into the housing? Maybe the 15 and 30 amp varieties, but I can't imagine that the 40A v-shaped connector would fit into the hole.
Regarding soldering, we have never soldered our Anderson connectors. Have teams had problems with wires falling out of crimped Anderson connectors?
Unread 09-03-2012, 12:33
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
We use these for superstructure power and we've found that unsoldered connectors suffice if they're crimped properly.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 09-03-2012, 12:50
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Wildstang has used this product for quite a while, longer than i've been on the team, and all that I know is that these connectors are very dependable. We've never had any issues with them, as far as i know. We'll crimp and solder them (it sounds like overkill, but we never want to lose to 71 because of an electrical issue ever again ), and we'll use them on speed controllers, spikes, motors, and basically anything else we need to remove easily. I'm sure one of my mentors could give better testimony, but from a student perspective, this product makes the electrical subteam's job much easier.
I definitely approve.
Unread 09-03-2012, 13:21
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
What's the mcmaster part number?
399 just started using the powerpoles this year. Can't live without them. Using powerpoles and some RJ45 connectors(for sensor lines) allow us to create completely modular subsystems. We have them at every motor connection.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I have been using these for about 8 years in FIRST have had very few issues. A couple reasons I have seen teams have issues is that they don't buy a real crimp tool for them, not some generic thing that doesn't do the job, a real one is only like $40. Another issue is they buy generic connectors, real Anderson's are very reliable. The number of times I have had to change a speed controller right before a match have led me to always want to be able to quick change any component so nearly everything has multiple Anderson connectors on it.
They can get expensive but it's completely worth it if it can save a match. If you buy in bulk you can easily get them for under $1 a pair.
Unread 09-03-2012, 13:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I have had issues before of certain pins in certain housings not making contact at times if the housings came slightly apart, and in RC cars I've had them pull apart often just from impact of landing from jumps. However, you can zip tie the two sides together.
We use them and like them for our FRC robot. Our whole superstructure is removable by 4 bolts, one large 4x2 Anderson Powerpole assembly, and a DB9.
Unread 09-03-2012, 14:30
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This year we returned to our habit of a removable electronics board, which really helped during the final days when we wanted to get into a tight spot to drill a rivet out and replace a minor part without getting shavings everywhere.
My team has been through several generations of quick-connects, and this year we're going with the gigantic Andersons (yes, the one for the battery). I personally don't like them as much because there's no way to reverse the connectors for quick debugging or quick retraction of an arm on a window motor (and they're huge). However, we used the big ones this year because (from what I've discerned in conversations) they have permanent mount holes built into them, whereas the mini andersons do not. Other than the zip-tie method, does anyone know of a way to perma-mount a mini-anderson pair?
We've also moved away from using clustered blocks of mini-andersons to connect parts of the robot -- everything is generally fine until a single motor in the block has to be replaced, at which point that one pair of connectors has to be pried out of the block. This wreaked havoc on us in 2008.
GitHub
