Go to Post FIRST has changed my life and I can never say thank you enough. - Jason Kixmiller [more]
Unread 09-03-2012, 15:09
chi-town-biker chi-town-biker is offline
FRC #3135 (Robotic Colonels)
chi-town-biker is an unknown quantity at this point
Re: [DFTF] Anderson Powerpole Connectors...
Originally Posted by JesseK View Post
Other than the zip-tie method, does anyone know of a way to perma-mount a mini-anderson pair?
These clamps work great with the powerpoles. They give a secure mounting point and ensure the plugs never come apart due to vibration. There's a tab on the back, we just cut it off and bolt the clamps flat on the electrical board.
http://www.powerwerx.com/powerpole-a...mp-2-sets.html
Unread 09-03-2012, 15:11
...we used the big ones this year because (from what I've discerned in conversations) they have permanent mount holes built into them, whereas the mini andersons do not. Other than the zip-tie method, does anyone know of a way to perma-mount a mini-anderson pair?
When you slide the connector housings together, there's a small hole that appears between them. I think it's intended for a pin to keep them from sliding apart again. On our cleanest and most modular control box, we put a small bolt (M3 might have been too large) through the hole to mount the connectors.
Unread 09-03-2012, 15:31
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
We use these clips in those holes. They work very well.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 09-03-2012, 17:28
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
The chassis mount for powerpoles featured here:
http://www.powerwerx.com/powerpole-a...nt-4-sets.html
and
http://www.powerwerx.com/powerpole-a...ch-4-sets.html
Are a DREAM. I used them in 2009, and its a great feeling to disconnect 4 motors at once. I imagine making a box one day with 2 or 3 of these and a good cable management system for any sensor inputs would make a removable electronics box so easy.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 09-03-2012, 17:48
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
I personally love powerpoles.
One thing I do is after I crim them I add a dab of solder so the wires dont fall out.
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Originally Posted by jeremypg399 View Post
What's the mcmaster part number?
8026K9 for 45A kits.
Unread 09-03-2012, 17:54
Originally Posted by DavidGitz View Post
Crimp Tool: http://www.westmountainradio.com/pro...ts_id=PWRcrimp
We followed the instructions as best as we could from Powerwerx, Westmountain and on here but all of the connections we made were very loose, i.e. after crimping the terminal on the wire and then inserting into the connector very little force was required to pull out the connector. We spent quite a bit of time trying to get this figured out, including talking to Powerwerx Tech Support (who admonished us for not using their Crimping Tool) to no avail.
Yeah as much as i dont like the idea of a special crimper, it works like magic.
We tried to go the first year without buying the crimper and it was the biggest hassle ever. To anyone thinking about getting started with powerpoles, DO NOT BE CHEAP, buy the crimper, it's worth the money saving the time and frustration and failed crimps. Get the crimper and use it and then making anderson connectors is the easiest thing ever.
Don't make the same mistake i did, you'll regret it
Unread 09-03-2012, 17:55
We've also moved away from using clustered blocks of mini-andersons to connect parts of the robot -- everything is generally fine until a single motor in the block has to be replaced, at which point that one pair of connectors has to be pried out of the block. This wreaked havoc on us in 2008.
Maybe you got a plastic-welded set, which some retailers sell; the standard individual modular connectors are very easy to separate by hand.
Unread 09-03-2012, 23:01
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
I'm not sure what you mean by "plastic-welded" set. Each connector contains 1 wire. We use the friction-fit shapes to put a red & black together. Getting them apart takes a pair of needle nose pliers about half the time.
2017 Scoring Model
CAD Library | GitHub
Unread 09-03-2012, 23:47
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Has any of our Ansel Adams wannabes here on CD taken some close-up, high resolution shots of good, bad, and ugly crimps? It's one thing to give a description or a tug-test mention and quite another to claim that a specific crimper is doing or not doing the job. I've got a crimper that I've used for nearly 50 years. It puts a dimple into the connector such that Herculean effort is required to break the result. Most tested times, the wire breaks and there are still crimped strands inside the connector. I may just make a gallery of crimps and the tools that made them, unless someone beats me to it.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 10-03-2012, 02:00
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
This cannot be stressed enough.
Buy the correct crimpers and not only will it be easier to crimp, it'll be dependable.
Our team went to making just about every electrical/control system component with connectors. This allows for easy assemble/disassemble when necessary.
Unread 10-03-2012, 02:40
FRC #2170
However, we used the big ones this year because (from what I've discerned in conversations) they have permanent mount holes built into them, whereas the mini andersons do not. Other than the zip-tie method, does anyone know of a way to perma-mount a mini-anderson pair?
There are several ways to mount powerpoles. One way is to use this mounting clamp set. Another uses things called mounting wings. Be sure to check the pictures on that site. They mention using in pairs, but I could see a string of connectors that goes, wing-pole-pole-wing-pole-pole-wing-pole-pole-wing for as many pairs as you need.
Not mentioned so far, is the "polarity" standard for PPoles. Viz., looking at the tongues of the cases, the black belongs on the right, and colored (red, yellow, blue, white etc.) on the left of the pair. You should resist the temptation to adjust wiring or programming errors by reversing the color sequences except very briefly for experimental reasons. One of the good things about powerpoles is always hitching matching colors together. You should be able to avoid hitching your drive motor to the elevator spike by using distinct colors for each connection you have. Don't depend on "it won't reach" as your connection strategy.
One more good thing is the ability to make extension cables using the 14ga. zip wire. (there goes "it won't reach!") You might not even have to get your removable control board all the way into its fighting position just to try out a simple program change by extending the connections involved in your test.
Unread 10-03-2012, 12:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
When properly crimped (powerpoles or anything), the wires should never fall out.
Unread 10-03-2012, 13:20
Soldering them gives a nice sense of security...
