Go to Post ...there's nothing worse than a problem you can't solve because you don't even know about it. - Dave Flowerday [more]
Unread 03-09-2012, 10:41 PM
tzjin tzjin is offline
AKA: Tony Jin
FRC #0192 (Gunn Robotics Team)
tzjin has a spectacular aura abouttzjin has a spectacular aura abouttzjin has a spectacular aura about
Different Types of Balls?
Hi all,
So we're currently at the regional in Chesapeake, and we've noticed that FIRST is using two distinct types of foam balls: red inside (firm), and yellow inside (soft). This is wrecking havoc with many compression-based shooters, since the ball trajectory and total distance will change so much. We've been fine, since we have been able to shoot at the fender and minimize the variation, but many teams have had autonomous completely wrecked.
Does anybody know if these balls will be standardized sometime soon (by St. Louis at least)? I'm sure many other teams have this question too.
With a smile,
Tony
With a smile,
Tony
Unread 03-09-2012, 10:46 PM
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Re: Different Types of Balls?
All the balls were all made in the same batch. I have not seen this and we have 25+ balls at our practice field. Only different between them are how much they have been used and the different compression, which as been already documented in many threads.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
superbotman's Avatar
superbotman superbotman is offline
John
FRC #2169 (KING TeC)
superbotman is an unknown quantity at this point
I have no idea what FIRST is thinking, but I would guess that they won't change because it is a interesting difficulty for teams to deal with.
*note: I don't know what they are thinking, this is just a personal opinion.
2011-2015 GoFIRST member at U of Minnesota
2009-present Head Referee at MN FTC Snowdrift State Championship
2008-2011 KING TeC (2169) Student member
Unread 03-09-2012, 10:49 PM
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Do you have any pictures documenting this discrepancy?
Our team heard of this issue and started this thread to discuss the problem.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 03-09-2012, 10:51 PM
AKA: Tony Jin
Our 30ish balls at home are also the same consistency, but at the regional there are very noticeable differences. I've felt them simply when I pick a ball up, since some are heavier and harder to squeeze.
Since there are some doubts, can some other team confirm if they noticed any differences? I may just be sleep deprived
With a smile,
Tony
Unread 03-09-2012, 10:57 PM
AKA: Pat Miller
The whole stiffness of the different balls has been documented in other threads already. But when it comes to a red and yellow inside that hasn't been mentioned. Newer balls are gonna be that way. When they started to be used they even out a little, but that is a design challenge of this years game.
Unread 03-09-2012, 11:01 PM
Billfred's Avatar
Billfred Billfred is offline
Our experience had to do with wear. Once the ball's surface has been scuffed up a bit (enough that air can escape easily), the ball becomes far squishier.
In 2006, we had alliance partners asking to cherry-pick from all of our bins (that year, each alliance could load ten). Might be something to consider if you're quick about it.
Unread 03-10-2012, 02:01 AM
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
After comparing game pieces to each other when practicing last weekend, we were shown a significant weight difference in two balls that were being used and actually came like that right out of the bag. Obviously, if game pieces were not regulated before the event, any lower or higher weighted ball would certainly be in play. However, I do believe that there was only some slight differences in terms of scoring. If there is an odd man out, I would try and score it as quick as possible and if possible as well as not using it for autonomous/hybrid if your routine is hindered with the slightest amount of difference.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 03-11-2012, 01:17 AM
Karibou Karibou is online now
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by tzjin View Post
Hi all,
With a smile,
Tony
Field reset point of view:
I specifically looked at Waterford after reading this Friday night, and I didn't see any balls with a yellow inside - just red/pinkish/orangeish (depending on the lighting) ones. What you may have been seeing is the yellow foam that is directly under the orange outer material of the ball - it is a very thin cushion similar to the material under the fabric of 2009's orbit balls. Occasionally the orange coating would be scraped off and some yellow would show, but any chunks out of the ball should show the pink.
New balls are definitely more firm than old balls.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 03-11-2012, 01:39 AM
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
From what I saw at Lake Superior regional the only difference in the balls were that some were beat up and torn a bit and some were basically new. Our team really did not mind at all since the only times our robot contacts the balls are at the start when we take 2 just to keep them off the CO-OP bridge and when we bump into them randomly since we are strictly defense/balance.
Unread 03-11-2012, 11:17 AM
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Don't let new balls get you down:
http://youtu.be/GxsalSrmCto
Unread 03-11-2012, 11:47 AM
FRC #1836 (MilkenKnights)
I wonder if that is Legal?
Unread 03-11-2012, 11:54 AM
O-H
The two refs watching it take place in front of them don't seem to mind.
dsalvucci dsalvucci is offline
FRC #0023 (PNTA)
Team Role: Driver
dsalvucci is an unknown quantity at this point
Team 23 didn't look into it since there was nothing we could do about it to help our situation at the time, but we noticed that by the end of qualifiers in WPI almost none of the balls were the same size anymore. At the same time, however, there were some that still fit into our cannon like brand new despite being torn apart. Whether it be different balls or just being worn down at different rates we are not sure.
Unfortunately for our team, being driven by fan power on a shooter, that meant our scoring power was severely crippled. We went from being one of the best scorers in the early matches to being one of the worst by the end. Had it not been for our ability to balance, Team 23 would've been dead in the water.
Unread 03-11-2012, 01:39 PM
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
I never thought of that, I might have to do it at the St. Louis Reigonal. Looks like a good way to break in the balls!
A bit off topic but, I was honored to be the 48th viewer of this video!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
