Go to Post What's the point of competing if you're not going to be competitive? - davepowers [more]
Unread 10-03-2012, 20:03
Andrew Lawrence
Posts: n/a
Re: Plaction wheels coming apart
History lesson--2001 had a bump. The trick there was you also had to go under a limbo bar to cross it--or use the tipping bridge (which wasn't self-leveling). 1999 also had a vertical bump, but it was mobile and more of a platform than a bump...
I think of this game as taking Aim High, using the Breakaway ball handling rules, reorienting and splitting the targets, and then adding the barrier and bridge from Diabolical Dynamics (2001) with a couple extra bridges.
This year's game couldn't have been explained better. I don't know too much about games prior to 2003, since our only alumni from 2001 time will only tell us it was the team's best robot ever (she designed it, of course ), and our team didn't compete in 2002.
Now I'm off to look at matches from 2001!
Originally Posted by Madison View Post
We completely destroyed several plaction wheels in 2010.
How? I've had to use a hammer before in the past to do something like that!
Unread 10-03-2012, 21:45
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Take a 120 pound robot, drive it over a 13.5" bump, hit the ground front wheels first at reasonable speed, that seems like it would do about as much if not more than a hammer.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 10-03-2012, 21:49
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
This explains a lot! I was wondering why we destroyed a set of kit wheels with tons of fractures around the hub areas. My first thought was that the sprocket was grossly over-tightened into the plastic but I'm realizing it was the loctite!
Sigh lesson learned!
1058 PVC Pirates 2016 - xxxx
Unread 11-03-2012, 12:25
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Here is what happens when you get Loctite on your polycarb wheels:
Former Mentor Team 1771
Former mentor Team 4509
Unread 11-03-2012, 17:37
BrandonGlatz BrandonGlatz is offline
Sparky
FRC #2865 (Roboteknix)
Team Role: Electrical
BrandonGlatz is on a distinguished road
I secured a victor with loctite once.... It is now a bare circuit board... the case just disintegrated >_<
