Go to Post It's easy to get so caught up in the intensity of build that we forget we need some down time to recharge and get a fresh head. Taking a day off will only happen if you make it a priority as important as any other team meeting. Long hours do not equate to productive hours. - Greg Hainsworth [more]
Unread 10-03-2012, 22:58
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Sandwich Bot
After seeing all the triple balances this weekend, I remembered a small robot I helped a rookie team (2250) design and build in 2007. It's purpose was to climb any robot ramp that year. Here's a video..........http://www.youtube.com/watch?v=rtD8v...P-bwefWlfnk%3D. It was affectionately known as ' mini me' and the rookie team was the 8th seed at the Colorado Regional that year. If you built a similar bot this year it could easily 'sandwich' between two other bots making a triple balance easy. You could easily fabricate a chassis and integral bumpers that would weigh less than 30 lbs. Together with a minimum of COTS components you could easily fabricate and drive a robot like this on the Thursday of a regional. You might also do well with this bot balancing on the coopertition bridge during qualifying matches. Then in elimination rounds with the right other two bots you could easily help make 40 plus scores a probability.
Unread 10-03-2012, 23:08
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Re: Sandwich Bot
or you could be team 956 and do it from the start
cole?
Unread 11-03-2012, 00:09
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Sandwich Bot
I don't recall there being any ramps in the 2007 game (Rack n Roll, right??)
Anyway, I saw a few "flat-bots" in the San Diego regional, but most were by rookie teams who just wanted to get their bot our there, and were generally full horizontal area which wouldn't help with balancing much.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 11-03-2012, 00:11
Andrew Lawrence
Posts: n/a
Re: Sandwich Bot
The end game of 2007 was to lift up your alliance partners on ramps.
Unread 11-03-2012, 00:30
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Sandwich Bot
Since it's related, I'll go ahead and post an idea I had here, I'm not sure if it's been done already.
We know from the piggy-back bots that you can intrude into your alliance partners' frame perimeters when you're on the bridge, so make a robot that "sandwiches" in the middle like this, but have drop-down catches that grab onto both other robots, preventing the end robots from falling off. This would require some decent pre-meditated coordination with alliance partners to ensure proper attachment points, but it seems like it could be useful in elims.
We tried to implement this idea over lunch on Saturday at the Pittsburgh Regional but ran out of time. If one thought ahead and was able to spend more than the hour that we had, though, it seems entirely do-able.
FRC 766, 2015-, Mentor
Unread 11-03-2012, 05:56
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
Re: Sandwich Bot
I was misled by this thread, hoping that it was about a robot that could make me a sandwich.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 11-03-2012, 06:42
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: Sandwich Bot
2013 game maybe...
Unread 11-03-2012, 08:26
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: Sandwich Bot
Originally Posted by Tom Ore View Post
2013 game maybe...
And the end game could be to deliver it with a refreshing beverage.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 11-03-2012, 08:38
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Sandwich Bot
Points are deducted for not making healthy choices "Aw they should have went with the tomato and basil wrap instead of the traditional white bun. That's a 20 point deduction. Too bad."
Unread 11-03-2012, 09:29
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Sandwich Bot
But if you can carry multiple drinks, without spilling them, you get bonus points.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 11-03-2012, 09:50
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Sandwich Bot
It's always fun til someone gets a soda to the CRIO.
Unread 11-03-2012, 11:13
Re: Sandwich Bot
Ooh! Can we get salsa too? I hear that Victors love spreading salsa with their fans!
Unread 11-03-2012, 15:45
galewind's Avatar
AKA: Chris Gregory
Re: Sandwich Bot
Thread derail: great success!
Chris G
Unread 11-03-2012, 16:05
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Sandwich Bot
Healthy choices are fine but even more points for bacon and toasting it is worth even more.
Back on topic
A little robot like this would make a great alliance partner if it also had the ability to play defense or intercept balls from your opponents inbounders.
Basically don't make it to short, something light weight on top that can block cameras and balls.
Unread 11-03-2012, 16:17
Team Role: Mascot
Re: Sandwich Bot
water game?
cole?
