Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Unread 11-03-2012, 13:51
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
The afterthought bridge manipulator
After our first regional this year, our team has learned a lot about this game.
One thing we (and quite a few other teams) didn't see coming was the difficulty of lowering those bridges.
Our bridge arm was the last system to be designed, and was not given enough weight/space allotment. For that reason, we ended up having a "you lower it and we'l follow you up there" robot. We tried at least two different designs both powered by a window motor, to no avail. Then again, with 5 pounds of weight to spare for a manipulator, what can you expect?
I'm curious as to who else was in this boat, and if they found a way to overcome this problem. It would be interesting to discuss last ditch bridge manipulator implementations, and their effectiveness.
Unread 11-03-2012, 13:57
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: The afterthought bridge manipulator
Every year there is always an aspect of the game that people underestimate that in the end cost them the opportunity to win the game. The ability to negotiate the bumps and manipulate the bridges is this year's bugaboo. I have seen plenty of robots helplessly paw at the bridge for the endgame and I have seen robots get stopped cold at the bump as if they hit a brick wall. I think teams figured scoring balls were more important and while it can make you dominant the ability to consistently make it on the bridge (especially the Coopertition Bridge during Qualification matches) is practically invaluable.
Unread 11-03-2012, 13:59
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
We were in the same boat, and it hurt.. a lot...
For off season I am thinking of just strapping a 1.5inch bore Pneumatic cylinder on the side of the robot and using that to push the bridge down.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 11-03-2012, 14:02
Sean Raia's Avatar
We had this same idea, we do not run a compressor on the robot though so this would be tough, UNLESS we charged our air before each match and never charged it on the field
Plausible?
I agree that bridge manipulation is invaluable, it's unfortunate that many of us cannot yet do it.
Unread 11-03-2012, 14:06
Mk.32's Avatar
AKA: Mark
From our last year experiences, think 2inch bore x 24 inch cylinder, we found it best to run a compressor on board for anything bigger then .75inches; your mileage may differ.
The biggest problem without running a compressor is tiny leaks, we per-charged this year and then by the time we got onto the field we found we lost already 15PSI.
Kim Masi's Avatar
Kim Masi Kim Masi is offline
125 Member, cause Brando says so :p
FRC #0125 (NUTRONS)
Kim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond repute
Send a message via AIM to Kim Masi
I watched a lot of teams (both veterans and rookies) struggle with this over the weekend. I'm not sure if the issue was more geometry or providing enough torque to the bridge to lower it.
One of the most clever methods I've seen is team 103, who has two curved pieces of tubing that flip down and so when they drive up to the bridge the natural motion of their forward momentum causes the bridge to tilt and allowed for them to get up pretty easily. It was a pretty effective, light weight and passive way of lowering the ramp without having to stop and wait for some other mechanism to push the bridge down. If I can find a pic I'll post it.
Or you could try the 25 method: bump the bridge, pop a wheelie and then get on. Seemed to work well for them
Bobcat Robotics-Team 177: 2004-2007
The NUTRONS-Team 125: 2008-2009, 2011-2012ish
Unread 11-03-2012, 14:12
SenorZ's Avatar
SenorZ SenorZ is online now
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Our regional is next week. After watching weeks 1 & 2 we're scrambling to make a bridge manipulator:
Andymark gearmotor (KOP) on a length of c-channel with a small wheel on the end.
This is untested and will not get a chance until Thursday.
Fingers crossed!
Unread 11-03-2012, 14:21
Andrew Lawrence
Posts: n/a
Fingers crossed!
Gear that down. A LOT. Make it go slower than molasses with gearing. You'll need he torque
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
We had the same problem in Smoky Mountains. Our bridge manipulator turned out to be the worst part of our robot. We tried to fix it but it eventually became this
So after the regional I started designing. I had 10 pounds to work with, 5 from the old one and then we sacrificed the angle changer on our shooter and will change the speed instead, which gave another 5 ish pounds.
This is what i designed
Down
Up
Current weight is about 6 pounds. We dont have to add any electronics because the old electronics are still there.
Though for us depending on another robot for a bridge manipulator worked! We are undefeated right now, and won Smoky Mountains.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 11-03-2012, 14:25
Sean Raia's Avatar
Down
Up
Nice design! Are you running a window motor to power that?
Unread 11-03-2012, 14:29
NO! lol sorry PLEASE DO NO USE A WINDOW MOTOR!!!!!!!!!! Im putting on a fisher price motor. The gearbox is there in the picture The old Bridge manipulator was a window motor, but it doesnt have nearly enough torque to push the bridge down.
2013-Present
2010-2013
Unread 11-03-2012, 14:30
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Word.
But we shouldn't have this dependency in Wisconsin.
Unread 11-03-2012, 14:51
We will definitely need a bridge manipulator if we want to be competitive against 1114, 2056 and 188 in GTR West.
2013-Present
2010-2013
Unread 11-03-2012, 15:01
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
We had originally designed our cannon to have a barrel extension which extended the length of the cannon when in the firing position, but realized the cannon was just barely long enough to get the bridge down. During build week 5, we reversed the extender to extend the cannon when it was in the down position, making it very easy to put the bridge down.
Unread 11-03-2012, 15:09
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
We haven't attended a regional yet (we are week four), but we have spent enough time going up/down bridges with our robot to comment here...
Our team prototyped a bridge manipulator that would push the bridge down, and like some of the other posters figured out that using an arm to do all the pushing was not as simple as some thought. The moment we thought we should change designs was when our robot ran over our bridge manipulator...
In the end, we created an mechanism that acts as a ramp, and uses the power of our drivetrain to lower the bridge. When approaching the bridge, the driver will lower the mechanism out over our bumpers, and hit the bridge. The lip of the bridge will slide down the ramp (like so: -evil bridge lip-\[robot here]). When the bridge's lip reaches the bottom the the ramp, the wheels will be able to roll onto the bridge.
