Go to Post 27 ft/s? They must really "Rush" around the field - Michael Corsetto [more]
Unread 11-03-2012, 14:25
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: URGENT Sending data over tcp
len is the number of bytes read by that specific call. Since there isn't always enough new data available to fill your buffer, read() lets you know exactly how much was there (or, more correctly, how much it copied into your buffer).
UDP is faster, but it's also a good bit riskier. TCP is nice because it guarantees that packets will arrive, that packets will not be corrupted, and that packets will arrive in the order they were sent. UDP guarantees nothing. However, since UDP doesn't have all those checks, it will be faster. Be careful using it, though, because you can no longer rely on any of the guarantees of TCP.
Unread 11-03-2012, 15:27
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Is UDP supported? i dont think it is in this version of java
