Go to Post Go figure that by teaching you end up learning a lot through the process. ;) - Josh Fox [more]
Unread 03-08-2012, 11:00 PM
pburr pburr is offline
FRC #2062
pburr is an unknown quantity at this point
Teleop transition issues, Labview
Team 2062 is having a problem where after hybrid period executes then the first frame of teleop executes but then the code gets hung up and does not continue. We had 2 NI CSA's look at our code and they could not find anything or help us. After the matches we talked to the FTA who said that the robot was communicating throughout the match but the robot received the signal from the FMS to turn to teleop but this did not reflect in our code (see log file attached). We put in some debugging to see where the robot got hung up and the code would work randomly half of the time. We serialized the code to prevent a race condition which the CSA said could be the problem but that did not fix the problem. The diagnostic lights on the jaguars using CAN are solid orange (good signal, neutral speed) and the diagnostic lights on the jaguars using PWM are slow falshing orange (bad PWM signal). We changed our program to send a message to the driver station each iteration of the teleop program and this verified that we go through only one frame of teleop.
Unread 03-09-2012, 12:13 AM
Re: Teleop transition issues, Labview
Whoa, that's a lot of stuff going on in Teleop. I don't see any reason for it to hang, though.
I notice that Robot Main has been modified. That's often a recipe for unexpected weirdness, but it doesn't seem to have anything in it that'll break things. I do wonder why you didn't just put that vision-receiving code in the Periodic Tasks vi, instead of doing clever background startup and shutdown processing.
Unread 03-09-2012, 06:35 AM
Using the Practice mode on the Driver Station in your pits and turning on Highlight Execution (the little lightbulb) while running the code from LabVIEW you may be able to see what VI may be getting stuck (unfortunately it's possible that the issue won't crop up with highlight execution enabled).
You should also check the Diagnostics tab and NetConsole to make sure no errors are being reported.
Unread 03-10-2012, 02:35 PM
I saw another team with similar sounding issues, but I just received their code and don't have a cRIO. Their workaround was to end their teleop loop at fourteen seconds.
I hope to get to the bottom of it late next week.
Greg Mckaskle
Unread 03-11-2012, 03:13 PM
the programmer's Avatar
the programmer the programmer is offline
AKA: Erik Orlowski
FRC #2830 (Riverside Robotigers)
the programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud of
Thanks for the help everyone. We ended up rewriting our code and sending the old code off to NI to have it looked at. We never really had a chance to get the old code working at this regional but we'll try to get it working for Wisconsin.
2006-2008: FLL Student
2009-2014: C.O.R.E. 2062
2010-?: FLL Referee
2015-?: Riverside Robotigers 2830
Unread 03-12-2012, 08:37 AM
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
To follow up with what's been said already...
We tried this, but unfortunately we could only reproduce the problem with built code (as opposed to just deployed). We added user messages to almost every bit of our code, which actually made the problem a little bit better, happening about half the time. When it did happen though, it was inconsistent as to where in the code it happened.
We ended up rewriting our whole teleop and autonomous code on Thursday night before our Qualification matches, and it preformed reasonably well (with a lot of between-matches scrum). By our second match in Qualifications we had gotten it back up to almost where it was.
The whole building issue is key here, as it could most likely be a bug that's been lurking in our codebase for a long time, as we never really tested our build code with a practice match. This lack of testing is something we have noticed and are taking steps to improve.
Proud alum of CORE 2062.
www.core2062.com
Unread 03-12-2012, 12:45 PM
Volunteer, WPILib Contributor
no team (Waiting for 2021)
We had this same problem at our regional, and we traced the problem to our CANJaguar GetStatus. When we had that vi running, the code would freeze running that VI when we would transition between auton and teleop. After we removed this, the code worked again.
Team 4488 - Mentor 2013-2016
