Go to Post This is a benefit of the district model. It brings the events back into the schools. - ezygmont708 [more]
Unread 11-03-2012, 15:16
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: weight withholding allowance question
A Commercial, Off-The-Shelf (COTS) item is defined as a part in its unaltered, unmodified state. A COTS item is a standard (i.e. not custom order) part that is or at one time been commonly available from a Vendor. Once a COTS item is modified in any way, it becomes a Fabricated Item.
Originally Posted by RRLedford View Post
If I can order extruded aluminum framing in cut-to-length sizes by just typing in the length on the ordering web page, is this considered custom or standard?
Unless the Vendor only provides or sells customer-requested lengths (in which case this question should be posed in a Q&A), it is considered custom; that is, if the Vendor offers any standard lengths or sizes for the object in question and you order a size that is not one of those, it is considered custom.
If it is COTS standard item, then, if I cut it in half, are the two halves considered COTS, or have they become custom?
This is a modification, which therefore makes it a custom part.
If I order a 36" piece of extrusion online, and then cut it into (3) 12" pieces before arriving at competition, can I still consider the pieces COTS?
No, you may not.
If Home Depot gives one free cut of lumber, can I consider any size piece of their lumber as COTS, or must I bring an 8" length and only cut it in the pits to the length I need.
See my first response.
What about fasteners? Can I buy 3" fully threaded fasteners, and then cut some down to 2" or 1" before competition, and then still consider the shorter ones COTS, or must I only cut them in the pits, in order to use them without counting toward the 30LB limit of custom stuff brought?
The latter.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 19-03-2012, 11:41
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
So, in order to bring in the maximum "under 30 lbs" worth of stuff considered to be customized assemblies, we are looking at stripping out most of their easily removable COTS component items that have previously been integrated into these customized assemblies, and then reassembling them in the the pits.
Is this considered an acceptable strategy within the rules?
-Dick Ledford
Unread 19-03-2012, 11:47
Dick,
[R26]
Teams may bring a maximum of 30 lbs of Fabricated Items to each competition event to be used to repair and/or upgrade their Robot at the competition site. The Operator Console and any battery assemblies (see[R03]-A) are not applicable.
That would suggest that COTS items removed from fabricated parts are not included in the 30lbs. However, if you modified any of the COTS items, i.e. machining on the shaft of a CIM, then that part is no longer a COTS item.
Unread 19-03-2012, 12:52
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
So using this logic;
[devil's advocate mode]
Batteries with the wires cut to length, Anderson connecters crimped or soldered count in the weight allowance? Is it specifically exempted?
Motors with the leads attached?
Andymark gear boxes that have been assembled from the as delivered condition?
Banebot gear boxes that have been disassembled, greased, & reassembled?
Raw stock that has been cut from the as delivered condition so that it will fit in the pit? It seems like previous years rules specially allowed this. Lost in the simplification?
[/devil's advocate mode]
Unread 19-03-2012, 13:42
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Batteries are explicitly expemted in the rules.
Banebots that have been greased but do not have motors assembled is something everyone seems to be letting go but I'm not sure of the official ruling. If the motors are assembled they are no longer COTS.
AM gearboxes that are assembled and not as delivered are no longer COTS as they have been assembled. This is equivalent to carrying in an assembled kitbot and saying it is COTS. Once you put that sweat equity in it is no longer a COTS part.
Raw material that is just cut for handling purposes is fine, however if your handling length is exactly what you need to make a part you designed for pit fab we both know you're lying.
This is an honor system and there are many of us that go to extraordinary measures to comply the rules, so if some one thinks they see something fishy be prepared to answer their questions.
Thank-you 294 & 67
www.bobcatrobotics.org
