Go to Post Just like any good hardware or software product, "insert foot before putting mouth in gear"..... - dhitchco [more]
Unread 06-03-2012, 16:38
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Twitter decoding program
Well, while it is easy to read the twitter results from the FMS (after getting used to it). I was wondering about if someone has already made a program that will use the Twitter feed and organize it into a more orderly fashion?
The Twitter I am talking about is the one that is done by the FMS at the regionals.
http://twitter.com/#!/frcfms
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 06-03-2012, 17:18
Re: Twitter decoding program
I have some Python code that will do this.
http://www.github.com/tombot/FmsGrabber
Unread 06-03-2012, 17:51
http://www.chiefdelphi.com/forums/frcspy.php?
http://www.chiefdelphi.com/forums/sh...d.php?t=104057
http://www.chiefdelphi.com/forums/sh...15&postcount=4
Unread 11-03-2012, 11:44
Lalaland1125 Lalaland1125 is offline
AKA: Ethan Steinberg
FRC #2429
Lalaland1125 is an unknown quantity at this point
Decided to make my own twitter decoding program that tries to gather the average points for the teams.
It outputs a csv file with the teams in one column, and the average fouls, score, etc points for each match that team was in.
File Type: h twittercurl.h (459 Bytes, 14 views)
Unread 11-03-2012, 15:57
Does anyone know:
1) why there was (and is) no Twitter data for Traverse City, and
2) is this data lost forever ?
Unread 11-03-2012, 16:06
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Does anyone know:
It seems this also holds true for the Oregon regional...
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 11-03-2012, 23:57
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
The twitter feed isn't the only source of data about match results. Here is the traverse city data, and here is the Oregon regional data.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 12-03-2012, 01:07
AKA: Kevin Emery
While those sites provide the match results, the twitter feed provides this as well as a break down of how the points were scored by each alliance (IIRC, bridge points, foul points, hybrid points, and tele-operated points). I have yet to find another source for this kind of data.
FRC 360: 2008-2011
Unread 12-03-2012, 14:44
Correct.
Also, see attachment. Does anyone know how the 205 TeleOp points number was computed for Team 67 at Waterford? Unlike the Hybrid and Bridge points, it does not seem to be equal to the total of the alliance TeleOp points scored in the 12 qual matches by the alliance in which Team 67 was a member.
Unread 12-03-2012, 15:40
It appears to be the sum of the twitter Teleop points and foul points. This raises the question as to whether the FMS is using the correct tiebreaker for ranking (teleop hoop points).
It would be great if someone with a working twitter parser could compare the ranking results when QS, hybrid, and bridge scores are all tied, to see which is being used as the tiebreaker. Looking at the Alamo regional, there were 2 cases of this 2721 tied with 4162 and 2583 tied with 2969. Unfortunately, the magnitude of difference between then team's TP were large enough that including foul points would be unlikely to change the ranking. I did not see any such ties at Kansas City, BAE, or Smokey Mountain, but there's still a lot of events I didn't look at.
I did ask about this on Q/A.
Unread 15-03-2012, 00:48
FRC #2429
I have now added least squares solving in order to better find the "impact" each team had on the score. The results are now much more accurate, and better predict the results in the final match( the total of the average scores from each team member is around +- 5 from the total score for that team(excluding outliers like team 93)).
( I am only using data from the qualifying matches to predict the final rounds)
While of course hand recording the individual scores of each team would be more accurate, this should be a great help in determining which teams provide the most "positive" points to help in the finals.
Unread 15-03-2012, 20:15
I have now added least squares solving in order to better find the "impact" each team had on the score. The results are now much more accurate...
Just a heads-up: the Twitter data has completeness issues:
http://www.chiefdelphi.com/forums/sh....php?p=1144595
http://www.chiefdelphi.com/forums/sh....php?p=1144727
Oh, and a couple questions: What linear algebra library are you using, and is there a reason you are using SVD?
Unread 16-03-2012, 00:12
FRC #2429
The math library is Eigen.
The reason why I am using SVD is because that is how Eigen's tutorials describe how to perform a least squares operation(http://eigen.tuxfamily.org/api/Tutor...Leastsqua res)
I don't think missing scores is going to be that bad. As long as most of the scores are posted, there should be enough data to get a reasonably accurate result. If anything, the main problem with my model is that it is very limited, not counting defense, autonomous, etc
Unread 16-03-2012, 16:52
SVD is just one (of many) ways to compute least squares. The choice of the "best" method to use (like choosing the right tool for a job) depends on the problem domain.
For this application, LDLT would be far faster* and plenty accurate.
Be aware: There are already two events (Oregon and Traverse City) for which data is missing for the entire event. No guarantee that won't happen for more events as the season rolls on. Not counting these two events, over 12% of the data is missing for the other events.
* For computing least squares for single events, the matrix is small enough that the time difference is probably not even noticeable. But if you ever intend to expand the functionality to compute least squares for a matrix containing all the data from an entire year's worth of events, I believe there would be a very noticeable difference in speed. If you have the time and are so inclined, it would be interesting if you would try SVD with 2011's data and see what the computation time is. For reference, LDLT takes 12 seconds on my 8-year-old PC to do least squares on a matrix populated with all the qual data from all the events in 2011
Name:	choose LDLT for symmetric semi-definite.png
Unread 21-03-2012, 18:08
Twitter data is missing entirely for the San Diego, Oregon, Traverse City, Sacramento, and Utah events.
The alliance selection algorithm in the qualification match scheduling software used for FRC events pretty much guarantees that the design matrix A (i.e. Ax≈b) will be full rank and well-conditioned. This means that forming the normal equations (Px=ATAx=ATb=S) and solving with Cholesky decomposition (LLT or LDLT) will give excellent numerical stability and accuracy and be far faster than other methods (and require much less memory). Furthermore, the normal equations can be formed directly in one pass (without the need to form the design matrix and multiply it by its transpose) when the raw data is read and parsed.
