Go to Post Scout so that you're not in doubt! - Mark Pettit [more]
Unread 11-03-2012, 16:42
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Re: The afterthought bridge manipulator
Originally Posted by BrendanB View Post
We are using the gearmotor to lower our ball pickup/bridge manipulator with a 2 to 1 ratio and we sometimes need to get the bridge rocking to get it down. I'd recommend a 3 to 1 ratio and you'll get that sucker down no problem.
A simple solution I saw at GSR was 1519's. It is a simple triangle driven by a window motor that comes down and they just drive into the bridge and it comes down. Can easily be down with a limited weight budget! You can see it on the side of there robot here!
This design interests me, I wish I could get a better pic of that manipulator. I'l go hunting...
@Akash, You mentioned using a van door motor. Does that have enough torque to push the bridge down on its own, or is it better off being used for a wedge?
Unread 12-03-2012, 08:52
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Originally Posted by Sean Raia View Post
This design interests me, I wish I could get a better pic of that manipulator. I'll go hunting...
Below is a somewhat better photo showing the 1519 bridge manipulator on the robot at the Granite State Regional. One of the keys to the design is that the motor alone does not hold the arm in the lowered position -- in addition to the motor, there is a servo-actuated latch which retains the arm in the lowered position so that the motor housing does not bear the load of the bridge when the robot drives into the bridge to press it down.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 12-03-2012, 09:51
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Depending on your design and use of "appendages" you could also use a "passive" latch using that is manually released after the match. But that would mean you are driving around with it permanently deployed if you have to manipulate a bridge early in a match.
At Chesapeake I noticed a good number of teams redesigning their bridge manipulators to either generate more force to be able to push the competition bridge down or to prevent the reaction force from damaging the deployment method.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
