Go to Post Screws come even smaller, #0000 - 160 at Small Parts.They're about $4 each, and made by elves. - DonRotolo [more]
Unread 11-03-2012, 04:16
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Custom Circuit (LED Ring Light) Requirements
I have an LED ring light to fit over our Axis camera on the robot, which requires 12V. For power I'll connect to the PDB with a 20 amp breaker, but I wanted to be able to use a DIO to toggle the light on and off (save power, not be distracting while testing).
To do this I want to use an NPN transistor then toggle the Base via DIO. To comply with custom circuit rules, what sort of protection do I need (if any)? I would think the LED's themselves would suffice as protection diodes.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 11-03-2012, 15:37
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Custom Circuit (LED Ring Light) Requirements
Have you considered hooking it to a Spike instead of building your own circuit?
Brian K
Team 1225 Robotics Mentor
Unread 11-03-2012, 15:43
I'm not clear on what you mean by the LEDs being their own protection diodes.
BK's spike suggestion is your easiest option. Otherwise, consider the NPN transistor to be part of your custom electronics (not a separate power controlling element) when you review the rules.
Unread 11-03-2012, 17:22
seg9585's Avatar
AKA: Eric
Yes but a spike relay costs $35 + extra weight and a transistor costs about $1.50. This is a low current application.
The concern with transistor is back-current from a load after power-off, so in my experience with integrated circuits we always need to add a diode to prevent said back current. In this case, the LEDs would serve its own purpose I'd think, but I just wasn't sure how inspectors treat custom circuits.
My FIRST legacy:
Unread 11-03-2012, 17:25
Originally Posted by seg9585 View Post
The concern with transistor is back-current from a load after power-off,...
That's only a concern with inductive loads. For controlling LEDs, don't worry about it.
