Go to Post I wish I had two extra hands, so I could give those gearboxes four thumbs up! - Billfred [more]
View Poll Results: Was this useful?
Yes, it was! It helped point out diamonds in the rough 109 70.32%
No, its numbers generally did not correspond to robot's actual on-field performance 46 29.68%
Voters: 155. You may not vote on this poll
Thread Tools Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
  #256   Spotlight this post!
Unread 07-03-2012, 19:20
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
Originally Posted by Bongle View Post
If you rename the temporary files to .html and try to view them in a browser, they should just be the FIRST results pages. If they aren't, or they look stylistically different than this one, then the parser that extracts the scores might be having trouble.
I believe that's the technique the matrix solving library I use (JAMA) uses. I don't know too many details about it.
Sorry, should have specified.
It doesn't ever return any results. After a second of thinking, it just shuts down, though I did notice it creating those two temp files.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
  #257   Spotlight this post!
Unread 07-03-2012, 19:48
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Here's v21: The only new feature is that it won't instantly shut down when it has an error. This should help debug your problem. If you run the current one from a command line that'd help too.
  #258   Spotlight this post!
Unread 07-03-2012, 21:29
BlacksmithWoods's Avatar
BlacksmithWoods BlacksmithWoods is offline
Mechanics / CAD
AKA: Brendan Woods
FRC #0806 (The Brooklyn Blacksmiths)
BlacksmithWoods is on a distinguished road
What does this mean? I keep getting:
 Failure to download results. Code -2147024809
Thanks!
Edit: Is this because I'm using v21 and I'm checking years prior to 2012?
2002 - Present FRC (806)
Keeping It Stupidly Simple since 2002
"You are done with designing something, not when there's nothing more to add, but when there's nothing left to remove." - EricH
NYC FRC STLA (2011- 2014) Practice Field / Alumni Relations
  #259   Spotlight this post!
Unread 07-03-2012, 22:55
For coefficient matrices associated with processing data from single events one at a time (even large events), LU is probably fine. But if you ever want to do computations for, say, an entire year's worth of data in one matrix (simultaneous solution using data from all events in the year), you might want to consider using Cholesky instead. It's twice as fast. The JAMA library you are using supports Cholesky.
  #260   Spotlight this post!
Unread 08-03-2012, 06:43
Bongle's Avatar
v22 - should fix the problems with downloading past-years results.
Ether, thanks for the tip.
  #261   Spotlight this post!
Unread 08-03-2012, 09:27
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Bongle, in the post-season I may assist you with some refactoring if you'd like. Extension of legacy code well after its expected end of life cycle is what I do best at work. Do you have the code up on a repository?
2017 Scoring Model
CAD Library | GitHub
  #262   Spotlight this post!
Unread 08-03-2012, 09:38
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is online now
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Here's v20. I made it so the overall OPR is also given the coopertition adjustment (coopertition points * 5, assuming that CPs are points you could have gotten if your alliance assigned you to a different bridge), and did a clean-and-build to attempt to fix the 0xc000007b errors people are getting.
Why wouldn't we want to have the Coopertition Points to time 10 instead of 5?
The Coop Bridge is the same maneuver as a 2-bot balance which is equal to 20 points. Also for bridge OPR I would use the BP + (CP*10) = Total Bridge Points.
This will assist team that are looking for good Bridge balancers.
-Clinton-
  #263   Spotlight this post!
Unread 08-03-2012, 10:44
Bongle's Avatar
-Clinton-
But CPs are handed out to both alliances and require both alliances to participate.
2-bot balance = 20 points granted to the 3-robot alliance that scored it = 60 robot-points.
co-op balance = 2 CPs granted to all 6 robots on the field = 12 robot-CPs. If we want it to be equivalent, then I think we should say it was 5 fake points per CP.
I could take the adjustment out entirely and make a 4th stat that just shows how many CPs a team is expected to achieve, then teams could apply their own adjustment if they felt like it.
I've got it on a local perforce server in my house, but nowhere else other than my intermittent source posts on CD. Since I'm unlikely to touch the code at all post-CMP, you could take the last source post I make, make the changes, then post it back on CD (or set up an actual repository).
  #264   Spotlight this post!
Unread 08-03-2012, 10:50
RogerR's Avatar
AKA: Roger Riquelme
I'm getting a message that says it can't download the results; does that have something to do with the firewall here at the school where I teach?
  #265   Spotlight this post!
Unread 08-03-2012, 10:54
Click on the link in this post:
http://www.chiefdelphi.com/forums/sh...&postcount=255
... and see if you have permission to download the data.
  #266   Spotlight this post!
Unread 11-03-2012, 20:06
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
I'm getting the same message, saying that I can not download the results. I tried clicking on the link in that post and it worked fine. Any other suggestions? If it helps the error code is: -2147024891, and I am using v22.
www.sharkattack744.com
  #267   Spotlight this post!
Unread 11-03-2012, 20:11
Bongle's Avatar
I actually had a similar problem earlier today - are you trying to run it from inside the zip file? I found that windows wouldn't permit the temporary file to be created if you ran it inside the zip file. Try copying OPRNet.exe to your desktop or something, then running it.
  #268   Spotlight this post!
Unread 11-03-2012, 20:13
Works perfectly now, thank you!
  #269   Spotlight this post!
Unread 11-03-2012, 20:23
Bongle's Avatar
Excellent, I confirmed it as well. Here's v23, which downloads to your windows temp folder (as reported by GetTempPath()) rather than the local folder. It also cleans up after itself when it is done, which the old version did not.
  #270   Spotlight this post!
Unread 11-03-2012, 21:34
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Its saying that the file is invalid or corrupted.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Offensive Power Ranking Calculations Greg Marra General Forum 4 18-03-2009 22:03
Offensive Power Rankings for 2008 Bongle General Forum 166 18-05-2008 15:05
Offensive+Defensive Power Rankings BornaE General Forum 4 05-04-2008 01:33
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
