Go to Post Courtesy is the key. - Tom Schindler [more]
Unread 11-03-2012, 16:55
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Bridge device failure fix
Many teams are finding out as they compete in their first event that their bridge manipulators are not strong enough to lower the competition bridges. We fell to this same fate, and spent our spare time at the event redesigning it. It was a simple enough fix that you could make a quick swap if you need it. I thought I'd share it on here, maybe someone else could get some use off of it. Excuse the paint drawing.
The red blob would be your bumper, COR is your center of rotation from the motor that is powering your device, and I drew in a badly drawn basic frame & front wheel. Note none if this is to scale. For best results, your COR should be around 12.5 to 13 inches off the ground. If its not, don't panic, you can modify the shape of the arm so that when the end is at its horizontal position it is ~12" off the ground.
There are three basic parts, labeled A B and C. Part A will extend from your center of rotation out of your frame horizontally to its max of 14" out of your frame. From that point, cut another piece (labeled B) so that the length allows it to go from the end of A to just in front of your frame below the bumper. Then simply make a final part (C) that holds B in place at the proper angle (which should be somewhere around 20 degrees, most likely, from part A ).
You just drop this arm down and drive into the bridge, and the edge of the bridge will follow the angle of part B and slide right into your wheel, and from there you just drive up. Its extremely smooth and reliable. Let me know if this helps anyone, just thought I'd post it up here. Remember to file and round any sharp edges!
EDIT: Works best with a window motor (worm gear) or van door (high torque, wont backdrive). I have no idea how it will react with other motors, you may need to lock it down somehow once its dropped.
Unread 11-03-2012, 16:59
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Re: Bridge device failure fix
I'd love to have your input here so we can keep everything in one place. Im confused as to how the part where b extends past c is supposed to swing down under your bumpers, but nonetheless thanks for sharing.
Unread 11-03-2012, 17:02
AKA: Brandon Liatys
I had the same worry when we built this, but when you raise the arm up from how its shown in the picture it didn't even touch the bumper. Just remember its not being raised/dropped straight up, its rotating down. I'll take exact measurements of ours when I get the chance to. But this is how we figured it out.
Unrelated, motor torque/power pretty much doesn't effect this. The fact that you have 120lbs of robot pushing against the bridge on an angle is what makes this work. You just need to make sure the arm stays horizontal.
Unread 11-03-2012, 17:11
I think what Sean Raia is saying is that your drawing is not to scale. See the green arrow pointing to where the blue circle intersects the red bumper.
Unread 11-03-2012, 17:14
AKA: Brandon Liatys
The drawing is not to scale, as noted in the first post. I will get exact measurements of everything we used when I can. With the addition of the circle you drew in, you can see how it does work if it were to scale.
Unread 11-03-2012, 17:19
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Do you know the angle formed between members A and B?
We can obviously figure it out with a bit of trig, but I don't want to rely on a not-to-scale sketch.
Hi!
Unread 11-03-2012, 17:26
AKA: Brandon Liatys
We found it by just placing a piece of the metal we were using from the end of A, then down to our frame, making sure when we rotated it it would clear the bumper. It was a on the spot trial and error type of thing. B will not actually touch your frame. Ours floats an inch or so in front of it. As long as the height of it is equal to or a bit below your frame, so that the bridge gets kicked under into your wheels.
Again, I will try go get measurements when we unbag for our 6 hours which would be this saturday.
Unread 11-03-2012, 20:21
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
How fast can you get on the bridge with your two front wheels from when the triangle thing first touches the bridge? (I would like to compare it to the speed of our pneumatic arm)
I see a lot of teams with this having to push against the bridge for quite a while before it comes down enough.
Unread 11-03-2012, 20:38
AKA: Brandon Liatys
with us, its the same speed your driving pretty much. The lower the angle, the better. The closer you get to 90 degrees the more its like hitting a wall, and more force is needed. my guess is ours came out around 20 degrees and its literally almost the same as just driving forward
Unread 11-03-2012, 21:08
E-Stop's Avatar
E-Stop E-Stop is offline
AKA: Alex West
FRC #0342 (Burning Magnetos)
Team Role: Electrical
E-Stop is an unknown quantity at this point
Most teams are using Window or Van door motors but we ended up with an Andy Mark geared motor from the KoP using a 35 chain with a 4:1 gear ration and it had more then enough torque at orlando and we even pushed from the side and can let robots up from the same side to balance themselves if we are doing the cooperation .
"If it ain't broke don't fix it and if it is broke find the duct tape"
Unread 11-03-2012, 21:53
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
Looks a whole lot like what we came up with 6-7 weeks ago. We made ours higher (14") off the floor in case the bridge isn't quite level, used a dogleg to get the Centre of Rotation (about 4" off the floor) lower to keep weight low and put adhesive-backed UHMW on the underside of it. We also left a gap in the bumper so it is much closer to the frame. We found that the weight of the robot with a 14" moment arm stripped the gears in the window motor in our first version so we added a pneumatic latch which engages when it's down. It also helps us get over the bump. When it's up, we can use it to tilt the bridge away from us. It doesn't slow us down much so far.
Unread 22-03-2012, 22:28
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Like most, are team cam to GTR with 2 window motors on a arm to lower the bridge, Did nothing. We then took a Cim with a tough box and attached that to the arm, again did nothing.
We are now using a 1 1/2" bore cylinder attached to a arm as a 3rd class lever. We get about 50lbs on the end of are arm. It also has the ability to raise the bridge and lock it in a balanced position. It's working great so far in the Waterloo regional.
Unread 22-03-2012, 23:38
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
We finally got to use our bridge manipulator today and found that you don't actually need all that shallow of an angle to get the bridge down. While I would certainly advocate a design like this if you have the room, we have a wedge that extends out around 7" but down 12" and still works (something like a 50 or 60 degree angle). You need a bit of a running start to make sure the bridge gets down well but we've balanced once in practice today and numerous times on the practice field with this so far.
Of course it may not hold up for an entire regional of beating, but we'll know that at the end of Saturday.
Also for teams throwing something like this on last minute, you don't have to use a motor to drive it if you have no other appendage outside the robot. We have a hinge and bungee cord to flip out the wedge as soon as the robot moves and it hangs out the entire match. Saved us the weight of a motor and the time of getting it hooked up.
Unread 22-03-2012, 23:56
AKA: Brandon Liatys
We found it will work with a larger angle, but it works smoother/doesn't require a head start with a smaller angle.
Unread 23-03-2012, 00:09
nitneylion452's Avatar
AKA: Joe Lee
Theoretically, this will work with any angle 0 < x < 90.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
