Go to Post I personally think any student should be allowed to participate, as long as he/she is helpful and active. FIRST, to me, is about inspiration, not elitism. - Aignam [more]
Unread 11-03-2012, 19:16
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
Lightbulb Blue or Red colored LEDs causing problems?
Hello. I was wondering since we are using a red LED, will it affect our vision tracking on the field since parts of the field are red. And if it does, what do you propose on how to fix it?
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 11-03-2012, 19:52
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Re: Blue or Red colored LEDs causing problems?
Use a green LED?
Unread 11-03-2012, 20:01
mega900997's Avatar
Lol, I wanted to know if there was any problem with tracking. I wanted to know if we had to switch out our LED or leave it.
Unread 11-03-2012, 20:51
om23 om23 is offline
AKA: Om Mahida
om23 is a jewel in the roughom23 is a jewel in the roughom23 is a jewel in the rough
yeah my team's using green LEDs for camera tracking.
you can also change the contrast
College Student | "It won't fail because of me."
Unread 11-03-2012, 21:12
Tejas,
The red parts of the field are on the floor or a few inches above it. Compared with the height of the retro rectangles, a little judicial aiming of the camera high will eliminate that.
Unread 11-03-2012, 22:29
mega900997's Avatar
True, true. Just wanted to make sure so that we wouldn't have any problems on the field with vision. Thanks guys and Good Luck at your Regionals
Unread 11-03-2012, 22:44
R1ffSurf3r R1ffSurf3r is offline
AKA: Charlie
FRC #0233 (The Pink Team)
Team Role: Driver
R1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to behold
with a blue light we didnt notice much interference with the field elements. however, our turret was really itching to target a glowing advertisement instead
Unread 12-03-2012, 01:51
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
If you used the Rectangular Target Tracking example for the basis of your tracking code, then you shouldn't have too much to worry about. Part of the code allows you to decide how close a target must be to rectangular before it is accepted as a target. Careful calibration should filter out just about everything except the targets above the hoops.
Unread 12-03-2012, 23:55
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
We use red LED's, but because of the nature of the retro-reflective tape and that of the Axis cameras, the rectangle returns as pure white. to process this, we use a gray scale image and identify the rectangle by the intensity of the light. This is an effective and efficient means of target identification.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Unread 13-03-2012, 00:23
aldenm aldenm is offline
FRC #2898
aldenm is an unknown quantity at this point
I think that your problem may have to do with field lighting interference. My team has had problems with lighting interference from the field lights. We are using green LEDs. Some people posted on my thread and recommended infrared LEDs, since the field lighting probably won't interfere with the IR light.
Unread 13-03-2012, 08:28
You guys know that due to the nature of the retro reflective tape, only light coming from your robot or directly in front of or behind your robot or the target is actually reflected back to your camera? The reason green LEDs work so well is human vision is more sensitive in the green spectrum so the camera is more sensitive in that area to mimick human vision.
If you are receiving a white image of the target, it is possible you are receiving so much light from the tape that the camera is actually white clipping the video. White clip prevents output video from exceeding a certain value and so additional light causes all three colors to "clip" off the top and return a monochrome signal above that level. The result is a zero chroma signal during that interval.
