Go to Post In FIRST, success = inspiration. - Daniel Brim [more]
Unread 21-02-2012, 17:10
playbass06 playbass06 is offline
"bass" as in the guitar, not a fish
AKA: Chris Schaaf
FRC #1986 (Team Titanium)
Team Role: Animator
playbass06 is an unknown quantity at this point
Send a message via AIM to playbass06 Send a message via Yahoo to playbass06
What do you suggest using for compositing?
I know Autodesk has their own, but I can't figure out how to even compile an image sequence or put audio in. Typically I just use Windows Live Movie Maker, but it doesn't do .mov (which can be solved by converting it later). So I was just curious as to what other teams use and if you had suggestions as to free programs out there.
Unread 21-02-2012, 19:19
240 Animation's Avatar
240 Animation 240 Animation is offline
AKA: Celia and Brynn
FRC #0240 (T.E.M.P.E.S.T.)
Team Role: Animator
240 Animation is an unknown quantity at this point
Re: What do you suggest using for compositing?
We just ran into the same problem. We have put it together using Windows Movie Maker, so how do you go about converting it into a .mov file?
Unread 26-02-2012, 14:11
AKA: Chris Schaaf
Team Role: Animator
WinFF is probably the most well-known free option: http://winff.org
It does a number of both audio and video formats, I've used it in years past. My main concern is if WMM can do multiple audio channels well. I don't know how we're going to be laying that out quite yet.
Unread 05-03-2012, 04:38
Francis115 Francis115 is offline
AKA: Daniel
FRC #3481 (Bronc Botz)
Team Role: CAD
Francis115 is an unknown quantity at this point
I use Adobe products such as After Effects and Premiere, both can export .MOV format files. What I do is I render the animation and output as an image sequence then I import the sequence into After Effects and composite it there.
Unread 12-03-2012, 01:33
AllieR2012 AllieR2012 is offline
Alumni turned Mentor
AKA: Allison Rich
FRC #2881 (Lady Cans)
AllieR2012 is an unknown quantity at this point
I tried to use Adobe Premiere but the quick time presets are different than the submission requirements. When I tried to create a custom preset, I got an API Failure error. Is there any way to fix that?
