Go to Post Brandon Martus, making CD readers' lives easier since May 2001/Fall 98 - Beth Sweet [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 12-03-2012, 09:58
Re: Infinite loop means no control
Originally Posted by tux View Post
No toggle meant that the autonomous code just kept on running in a loop waiting for the switch to toggle.
You absolutely must check which mode you are in during every loop. Failure to do so may mean that your program will not change modes when the field changes mode.
I think this is an issue no matter which programming method is used, but I'm not really sure.
I'm not a LabVIEW guru, but I was under the impression that "getting stuck in autonomous" is not an issue with the FRC LabVIEW framework, because it automatically shuts down autonomous at the end of the autonomous period.
Could a knowledgeable LabVIEW person please comment?
