Go to Post Step 1. Understand the game and how to win the match and the event. - Chris Fultz [more]
Unread 12-03-2012, 12:36
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Disabled Mode Alignment Indicator light
(I apologize for my lack of knowledge of the rules, I am very very far from familiar with them)
Is it legal for a robot to use an indicator LED during the disabled period (during setup)? The intended use would be to use the camera to determine if the robot is properly positioned for scoring once autonomous begins.
It seems like this should be technically possible, but I'm not sure about the rules, and just want to make sure I don't start down a bad path.
Thanks in advance.
Unread 12-03-2012, 12:37
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Disabled Mode Alignment Indicator light
All of the outputs are disabled in disabled mode, but you can send data to the dashboard in disabled, where you could send this indicator to.
Team 4488 - Mentor 2013-2016
Unread 12-03-2012, 12:44
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Would it work to add a custom dashboard output with a bright green light on a stick that is visible from the field? Is it possible to do vision processing on the cRIO when it is disabled?
Unread 12-03-2012, 12:47
The vision processing does run when the cRIO is disabled, and you could do the custom dashboard output.
Unread 12-03-2012, 13:14
The camera and cRIO are working while Disabled.
You could use the User1 LED on the cRIO itself as an indicator that you're on target. That also works during the Disabled state.
Unread 12-03-2012, 13:23
Programming Mentor
AKA: Joe S
How do you go about addressing that LED? I wasn't aware there was a usable LED on the cRIO.
Unread 12-03-2012, 14:03
Depends on your programming language of course, but it's called WPI-UtilitiesFRC LEDs.
In LabVIEW it's already being used in Periodic Tasks.vi and looks like the attachment below.
The LV vi is found in WPI Robotics Library -> Utilities
Unread 12-03-2012, 14:06
In C++, you can use SetRIOUserLED, defined in Utility.h, to set the LED. You can also control the FPGA LED similarly. Even better, you can read the user DIP switch for last-minute configuration, but that's not very useful if you're using a cRIO-FRCII since the "hard switch" is now in software.
Unread 16-03-2012, 23:40
Andy A. Andy A. is offline
Getting old
FRC #0095
Something to consider is that there is a significant delay between when you power up the robot, and when it connects to the field and driver station. If the field reset crew is trying to make up time, they will shoo you right off the field as soon as the robot is on the ground and turned on. You may not have time to wait for the robot to connect and get feedback.
It can be done, but I wouldn't want to depend on it.
Unread 17-03-2012, 21:38
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
From my experiences, I've found that DIO on the Digital Sidecar works just fine in disabled.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
