Go to Post You lame pig farmer! I'm not talking about a bunch of dudes sitting around eating their packed lunches that Mommy made. - Paul Copioli [more]
Unread 11-03-2012, 17:24
Volunteer, WPILib Contributor
no team (Waiting for 2021)
High Power LED's
We just went to our first regional, and had many problems with our camera tracking. We determined that this was caused by 2 things. 1 our light was not bright enough so we need a new light. The second thing was that the light would dim as we spun up our shooter because of the voltage drop on the system. We think we have the solution to problem 1, but I have questions about the legality of using a custom 12v regulator to solve the second problem. We would like to be able to turn the light on and off during the match. What would be a way that we could do this legally and quickly, because our next competition is in 2 weeks.
Thanks
Team 4488 - Mentor 2013-2016
Unread 11-03-2012, 17:48
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Re: High Power LED's
I'm not much for electrical, but I think I've heard of lighting circuits being run through a spike.
I feel like I'm totally wrong, but it would theoretically work.
Unread 11-03-2012, 17:50
We currently do that, but looking at the rules it doesn't look like you can put a regulator on the spike, so to do this would be a different circuit.
Unread 11-03-2012, 17:57
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: High Power LED's
The only way I know of would be to design a custom circuit utilizing capacitors to fill in the voltage drop during spin up of your shooter. Use the spike to turn the circuit on- off. Sorry, but I can't design the circuit for you, but someone out there should be able to help.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 11-03-2012, 19:04
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Attached, is our schematic for our custom LED driver board circuit.
The relevant part is the capacitor stage.
Depending on your robot and light, anywhere above 4000 microfarads would suffice. Unless you put a diode into the circuit, the rest of the robot will also draw power from the capacitor bank, nearly defeating the entire purpose of the bank.
Since you are powering this via a spike, you can turn it into a custom circuit and still be legal.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 11-03-2012, 19:12
Thank you very much. we might have to do something like this. I didnt know you could do stuff like this between a spike. but we will have both systems ready for competition just in case.
Unread 11-03-2012, 21:19
Guys,
Generally caps are not going to fill in the current needed for the length of time that the battery browns out. You can very easily use a LM317 three terminal regulator as a custom circuit set for 5 or 6 volts with just two resistors. If you connect the reference terminal to a digital output, you can turn the supply on or off. Then it is a simple matter of wiring your LED string for the voltage you have chosen. Please remember to isolate and insulate your custom circuit.
Unread 11-03-2012, 22:25
Ok. We were wanting to have 12 volts because our led's are currently wired for 12 volts. also would it be allowable to put a voltage regulation circuit between a spike and the led's or would that be disallowed?
Unread 12-03-2012, 03:12
rthinman rthinman is offline
AKA: Rod Hinman
FRC #3881 (WHEAbots)
rthinman is an unknown quantity at this point
You can get a quick estimate of whether those 4000 uF and diode will be sufficient or a waste of time. Assume:
The LEDs draw constant current I (they won't, that's why they dim)
The battery drops out for a time deltaT, perhaps 2 seconds, while the shooter spins up. For that entire time, it is lower than the capacitor voltage so the diode is off.
We can only tolerate a certain amount of drop deltaV in the LED supply voltage before our constant current assumption is now longer good, or that the LEDs are too dim. Maybe use 1 Volt for deltaV.
Now since we've made assumptions of constant current, we ignore the calculus and estimate:
I = C * deltaV/deltaT ==> C = I * deltaT/deltaV
With the above assumptions and I = 200 mA, we get C = 0.4 F = 400,000 uF.
You will probably want C much bigger than that to cover our assumptions.
So Al is right, ordinary capacitors generally won't cut it. Super capacitors (also known as ultracapacitors and "gold" capacitors) would be a possibility, but they come with other problems. You will want to put a small-value resistor of sufficient wattage rating in series with the diode to temper the inrush current when you turn on the Spike.
Rod
Unread 12-03-2012, 07:31
You can use a Spike to supply power to a constant voltage (boost/buck) supply to run 12 volts to your LEDs. Check out the power supply in the PD. You may also find these types of supplies in the Digikey catalog. Not cheap but exactly what you want.
Unread 12-03-2012, 14:02
Thanks for the rules clarification because this will make it alot easier.
Unread 12-03-2012, 14:47
Jay Meldrum's Avatar
Jay Meldrum Jay Meldrum is offline
FRC #0067 (H.O.T.)
Jay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud of
We are currently using the Angel Eye Headlight Accent Lights 60mm Blue and they worked great for us for vision tracking at our latest competition.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini_tubes. htm
We just placed it right over the camera (M1011). We do get a dimming effect when we start up our cannon motors, however this has not yet affected our camera tracking.
Unread 15-03-2012, 22:19
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
Hi all,
The best way I can think of is to make a circuit for constant current. They make driver chips for just that purpose. You could also use the LM317 in a constant current mode.
Just google constant current LED driver and you will get a ton of hits.
You can probably only put 3 LEDs in a string as 4 might be too much of a voltage drop.
Good luck, and have fun,
Mike
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
