Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 12-03-2012, 14:08
Jay Meldrum's Avatar
Jay Meldrum Jay Meldrum is offline
FRC #0067 (H.O.T.)
Jay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud of
Re: Camera Crosshair on Dashboard
Why not use the overlay feature of the camera. Make a simple transparent image with a line through the middle (Make sure the image size is what ever image size you have the camera set to. i.e 640x480, 320x240, etc). Connect to the camera through you're web browser via 10.xx.xx.11 (if you connecting it to the router). Upload your image to the camera. When reading the camera image you will now have that image overlayed on the image.
http://www.axis.com/files/manuals/um...38_en_1101.pdf Page 19
Last edited by Jay Meldrum : 12-03-2012 at 14:15. Reason: Corrected URL for M1011 camera
Unread 16-03-2012, 10:24
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Awesome tip! I didn't see that while I was in the camera, may have to try this.
