Go to Post Tolerance, forgiveness, humor, and lessons learned are tools we can find here. - JaneYoung [more]
Unread 12-03-2012, 15:20
evilcrouton evilcrouton is offline
FRC #2851
evilcrouton is an unknown quantity at this point
Auton to tele-op delay
At our last regional, we saw about a 5 second delay from when tele-op should have started. We are using iterative robot, but have not changed the file, and there is no delay coded into autonomousPeriodic(). Can anyone give suggestions to what could be the cause of this issue? This seems to be the same issue that some teams using Labview are also having.
Unread 12-03-2012, 15:24
Jared Russell's Avatar
Taking a year (mostly) off
Re: Auton to tele-op delay
The problem is almost certainly in your code.
By any chance, do you instantiate a new Gyro object in your TeleopInit function?
Unread 10-04-2012, 17:24
sarangmittal's Avatar
sarangmittal sarangmittal is offline
FRC #1683 (Techno Titans)
sarangmittal is an unknown quantity at this point
There may be a loop that starts in teleopinit that causes teleopinit to stay in that state until the loop is completed.
Unread 10-04-2012, 19:01
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Check under 1 of the menus of the DS. There should be a set of fields to change the Autonomous period, Teleop period, End-game period, and I believe there is also a Delay field. See if that is set to 5 seconds.
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
