Go to Post Personally, I think the solution involves looking at the past. - Billfred [more]
Unread 12-03-2012, 16:48
Re: Auto Code NOT Running (as expected)
Originally Posted by kws4000 View Post
Annnddddddddd, (drum roll please)
So therefore, is it some error in setting up the Kinect, or can the robot not reliabley interpret the Kinect data?
If you run the default dashboard, does the Kinect "green man" and Y-axis data show up?
Unread 12-03-2012, 16:51
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
yep. The little bars work fine, but the robot won't reliably read the kinect and sentd that data back to a custom readout, and yes the indicator works properly just like the other 2 windows we have right above it.
I think if the dashboard can finally get the proper data, then the robot auto code will work fine.
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
