Go to Post Where's my hammer? I need a bigger hammer. - JaneYoung [more]
Unread 12-03-2012, 17:02
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Re: Auto Code NOT Running (as expected)
Alrighty, I sacrifice confidentiality for operation.
Name:	auto kinect.png
ID:	12294  Click image for larger version
ID:	12295  Click image for larger version
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 12-03-2012, 17:46
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
The output of your feedback node in that snippet never changes.
Nor is it supposed to. If I recall correctly, the OP wanted something to do with total time elapsed since the start of auto mode (i.e. drive motor A for 7 seconds, then turn it off). The snippet will calculate the total time elapsed since the first iteration (not the time elapsed since the previous iteration, which is what I think you interpreted it to be). Make sense?
However, I probably could have phrased my explanation of the code better. Saying change in timer value probably implied change over one iteration, rather than over total execution. I intended the latter.
Unread 12-03-2012, 17:51
Originally Posted by kws4000 View Post
Also, sending kinect2 yaxis back to dashboard. Always sends "0", even when doing the floppy chicken!
So therefore, is it some error in setting up the Kinect, or can the robot not reliabley interpret the Kinect data?
By any chance do you have the Driver Station I/O Tab set to Enhanced Mode without the Cypress connected?
That's a unique case (bug) where the Kinect data will not get sent properly to the robot, but will be seen just fine on the Dashboard Kinect skeleton feedback.
Unread 12-03-2012, 17:52
Left and right motors are never set in your auto loop. If you open it, leave the safety enabled, and don't update it, the RobotDrive will complain and set it to zero.
If you set the left right drive, I predict the error will go away. Other choice is to disable the safety. This is primarily there to make debugging safer and isn't required by the field. If debugging with it off, the robot should be on blocks since a breakpoint will leave drive motors running.
I couldn't tell if you had a Kinect issue or not. Please summarize the symptoms.
Greg Mckaskle
Unread 12-03-2012, 17:53
OK sorry I misunderstood the OP's intent.
Unread 12-03-2012, 18:32
kws4000's Avatar
AKA: Krazy Karl
That may be it, Mark. We'll try it either tomarrow or Wednesday, we may be doing something with team Wavelength in Norton Shores.
Otherwise, code looks good? If it ain't, I'll never hear the end of it!
Mentoring:
