Go to Post I think this post is a lot of words saying "My name is Billfred and I approve MiniBots 2017" - Andrew Schreiber [more]
Unread 12-03-2012, 20:52
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
polycord and yellow belt
From what I've seen most teams (including ours) are either using yellow belt or polycord for an elevator from the ground to the shooter/ launching device. What is the worst thing that has happened with your teams cord whether its snapping or something else. I just curious if teams have problems with these things.
Unread 12-03-2012, 20:54
dodar's Avatar
dodar dodar is online now
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: polycord and yellow belt
I'd say ours is the cords walking around on the rollers.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 12-03-2012, 21:07
DonRotolo's Avatar
Back to humble
FRC #0832
The worst thing that happened to our orange urethane belting is that students got this idea to cut and re-join it after almost every match "just in case". sheesh.
Unread 12-03-2012, 21:11
I'm back
AKA: Matthew Lantry
Oh Don i never told u we only did it at the most twice a day
Unread 12-03-2012, 21:18
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
We've been using polycord since 2010, and honestly, no problems. As long as we follow the instructions and cut it 11% shorter than measured, it works beautifully. It doesn't just work for applications like collecting balls; if you want to prevent a motor from stalling, use polycord on a pully designed for a toothed belt, and the polycord will start to slip before the motor stalls. You can change its tension to adjust how much force it takes to make it slip.
The belts on our grabber in 2011 would fall off every once in a while, but that was more a symptom of the design of the rollers than anything else. It wasn't a problem, either; there were 4 belts on each side, and it only took 1 for the grabber to work. It was also the only part of the robot that worked at all that year, but at least it gave us something to be proud of, dog toys and all!
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
470-RBTX's Avatar
470-RBTX 470-RBTX is offline
Team Schmooze Captain
FRC #0470 (Alpha Omega Robotics)
470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of470-RBTX has much to be proud of
The poly belting is some of the most durable stuff I've ever seen and used. 470 used belting from our Lunacy bot (which has endured 3 FIM competitions and countless demonstrations) on this years robot, and have had no problems with it. We just cut it to dimension and and rejoin it and it keeps holding strong, in the 3 years of us using that robot it's never snapped.
Unread 12-03-2012, 21:36
Billfred's Avatar
Billfred Billfred is offline
This is the problem we've had this year; we've tried to fix it by limiting the cord's ability to walk.
Unread 12-03-2012, 21:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We first used it this year, it's been working fine for us, no problems. It did take us a little while to figure out how to keep it in place, we figured this out on our prototype and it's been working fine on our robot.
We're using a "comb" to keep the cords in place, at one end. They run on very simple ABS rollers. We used the connectors and hollow cord, and only about 3% stretch.
Unread 12-03-2012, 22:19
Billfred's Avatar
Do you have a photo of this comb? (We used 5% stretch, though our belts are welded.)
Unread 12-03-2012, 22:21
MrForbes's Avatar
AKA: Jim
sure....I have pics of almost everything!
Unread 12-03-2012, 22:24
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Second the picture motion. Our polycord was coming off our pulleys/rollers as well, but decreasing the amount of ball compression helped a TON, and we still could increase the amount of stretch in the polycord.
Something we considered but haven't done was switching over to rapid prototyping instead of pulleys.
-Duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 12-03-2012, 22:32
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
We love our poly cord, we don't have a problem with walking, maybe once or twice at max (were using custom rollers with grooves cut in them) and the welds are strong as can be. We did a test weld to test its strength (put it in a vice and pulled on it) and it was amazing, after 3 students and a mentor pulled on it, all it did was stretch.
Unread 12-03-2012, 22:39
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
We are using Squirrel's comb. Except we made it out of 1/16" plexi. Works great.
Unread 12-03-2012, 22:41
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Here is a picture of our "comb" for the belting. It will walk a little if a ball goes through, but it then walks back.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 12-03-2012, 22:42
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
We are using 3% stretch on solid "welded" polycord. All seems well. What do others see as the advantage of greater amounts of stretch?
Jim
