Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 06-03-2012, 17:27
rivasm rivasm is offline
FRC #2556 (RadioActive Roaches)
rivasm is an unknown quantity at this point
Robot Main VI cannot deploy
We are trying to run as startup but we have hit a wall. When labview checks for conflicts the Robot Main VI says that it is part of a real-time start up application. All VI's on this target will be closed of you choose to continue with deployment. We have received this error every time we run as startup with other VIs, but never with the main vi. When we try to connect wirelessly, we get communication, but no robot code, the same thing happens when we tether the robot.
Unread 06-03-2012, 18:59
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Robot Main VI cannot deploy
This is a normal message that tells you there is already code running on the robot. Simply click "ok" and the cRio will shut down the code that's running, load your new code, and start running that.
Unread 12-03-2012, 23:48
No, see, it was different. It was shutting down the main and everything inside it-- not just a warning that we had code on it already. Anyway, we luckily fixed our problem by changed a variable in our vision processing from Intensity to just Vision.
