Go to Post Is FIRST making it too easy?... yes they are making it easier than years past. But I would also say that does that matter? If students are still inspired to pursue more advanced designs and eventually a career in the technology sector we still have met our ultimate goal. - MikeDubreuil [more]
Unread 13-03-2012, 07:26
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: How are bellypans made?
FRC2168 has been using this stuff the last few years: McMaster 84825K89
I learned about it while at college with FRC229, they used it for their ramps back in 2007. It's listed as Noncorrugated Panels, is about 1/4" but the stuff is super light weight and can handle a good amount of weight.
Note: I've heard it called Polygal, but I believe that is the whole Kleenex vs tissue paper argument.
Unread 13-03-2012, 07:49
Gdeaver Gdeaver is offline
FRC #1640
To give the students some exposure to composites, we use a piece of 1/4" plywood laminated with 6 oz. carbon on both sides.
Unread 13-03-2012, 09:00
Andrew Lawrence
Posts: n/a
Originally Posted by R.C. View Post
We do ours like like Pink -> 254 -> 968 etc...
Basically 6061 - T6 Aluminum @ 1/8th thick.
We basically start off by making the diamonds, then adding elc holes/cutouts into it. Finish the CAD, send it off to a laser guy and its all g2g from there.
-RC
Where to do you get yours? Can the 6061 be waterjetted instead?
Unread 13-03-2012, 09:35
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Any metal supplier will have 6061 sheet. Yes a waterjet works the same.
Mentor 2415
Andrew Lawrence
Posts: n/a
Thanks!
Unread 13-03-2012, 09:42
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Last year we used a honeycomb fiberglass, the only problem was that some adhesives, such as Velcro tape, did not stick well. You can drill holes for support but you must have washers along with the nuts for the bolts.
Unread 13-03-2012, 09:45
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
We use this for mounting electronics and other materials. Lightweight, easy to mount to, easy to work with -
http://www.andymark.com/product-p/am-0836.htm
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 13-03-2012, 09:47
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Use fiberglass instead carbon if mounting electronics, or coated it with some clear coats. Same with using aluminum sheet, paint it so it's not conductive. I've seen too many times a live wire come loose and touch the mounting board. Also instead of plywood, use a foam core and save yourself a ton weight!
Unread 13-03-2012, 12:22
CallieJ's Avatar
CallieJ CallieJ is offline
The Girl With the Spirit Tattoos
FRC #1868 (Space Cookies)
Team Role: Scout
CallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to beholdCallieJ is a splendid one to behold
We CAD ours and a sponsor water-jets it from 1/4 inch aluminum. We then tap directly into it and attach our electronics that way.
Previous to this we used ABS and nuts and bolts. However, in 2010 and 2011 we had so little clearance under the robot that we had to tap the baseplate or countersink flat-head bolts from the bottom up.
2009,10,11 Silicon Valley Regional Finalists
2011 Silicon Valley Regional Chairman's Winners
2011 Sacramento Regional Champions
2011 Sacramento Regional Engineering Inspiration Award
2009 Silicon Valley Regional Engineering Inspiration Award
2006 Championships Judge's Award
www.spacecookies.org
Unread 13-03-2012, 12:36
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Last year, 1370 used 3/4" plywood (Lowes) to mount all of the electronics on. This year, because we were afraid of the weight limit (rightly so, it turns out), we used 1/8" Lexan. Band saws, vertical mills, and circular saws with either forward or reversed blades works just fine. Unfortunately, our Lexan was a little too gummy to use the tried-and-true method of score it and snap it at the line.
Unread 13-03-2012, 12:54
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
2079 laser cuts 1/16 5052 aluminum sheets. The only reason we use 5052 is because we put flanges on the edges, but 6061 is stiffer (or at least a standard T6 temper is). Our shop doesn't like to laser thick aluminum because of its reflective properties that damage the laser, but if you want to do thick stuff you can use a waterjet. I don't see a need to use anything thicker than 1/8 for a belly pan anyway, but I guess there could be a reason sometime.
Unread 13-03-2012, 13:04
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
6061 T6 is not stiffer, but it is stronger. Nearly all aluminum alloys have essentially the same stiffness (elastic modulus).
Unread 13-03-2012, 13:10
We used .09 laser cut 5052-H32 sheet. It was bent with the back piece of the chassis as the flange (suggested to us by Sean from 2415). We did not add much lightening this year, but for next year we will definitely be using the diamond pattern commonly used by 254 etc.. Here's a picture
Unread 13-03-2012, 13:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you can score and snap it, it's not polycarbonate! It's most likely acrylic (Plexiglass).
I'm not too keen on starting with a material that needs a lot of cutting to make it do the job, for any part of the robot. But I guess if you have access to machinery that can do this, and you like drawing neat designs in CAD, then it kind of makes sense. We usually do fine with a sheet of plywood, of a suitable thickness for what's attaching to it and how big of an area it spans.
Unread 13-03-2012, 14:56
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
I have used 5052 and 6061 on belly pans with great success in each. The 5052 does flex a smidge more I found, but overall does what it needs to. Its what the sponsor had on hand at quick supply so we dealt with it. Even had to cut one of the belly pans in half since we had parts that didn't hit the tolerance we needed by some random chance. I'm not sure what happened but the bending was free so I'm not complaining.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
