Re: Removing High Speed in AM Super Shifter
You could use a retaining compound like loctite 680 and literally glue the dog gear and shaft in place.
To remove the gears you will need to replace them with some kind of spacer. |
You could use the spring return cylinders, they hold u in low gear until air is applied to shift to high. They would hold you in low just fine with nothing hooked to them
You wouldn't loose the weight of the gears and cylinders, but the rest of the air system could go if you didn't need it. Last edited by BJT : 13-03-2012 at 13:01. |
In 2010 we turned an AM Shifter (Gen 1) into a single speed box simply by removing gears and locking the dog in place with a spacer.
EDIT: Here is a picture of the modification that maybe able to be used on a SuperShifter Last edited by akoscielski3 : 13-03-2012 at 13:13. |
Thanks guys. I think were gonna attempt the spacer idea because we already use the spring return air cylinders and we just want to cut as much weight as possible. Removing the gears and all associated air is the main goal and we think the spacer is the best idea. Hopefully it will give us enough weight to change our arm
I think you can also use a bolt and nuts to hold the "shift lever" to where you want it (similate the pneumatic in or out).
I think the fitting where the pneumatic connects is a 1/4-28, so use the right bolt! |
#7
The low gear is really low - usually close to 5 - 7 fps. That is really slow.
#8
If you have the money, why not look for a solid toughbox gear reduction you like for a quicker fix?
#9
This. If you want a good, one speed gearbox, use Andymark's CIMple box that came in the kit. It's not only a good one speed, but it's also lighter than the AM SS, so you'll not only get your preferred speed, but loose robot weight in the process. It's a win-win scenario.
#10
Final speed depends on your wheel size and any output ratio from chain/belts. In 2010 when we locked our 2 speed, we put it in high gear and increased the final chain reduction to obtain a speed of about 9 feet per second.
