Go to Post Remember, everything you do while on the team reflects on your team. Good reputations are difficult to build and easily destroyed. - Daniel_LaFleur [more]
Unread 13-03-2012, 12:37
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Removing High Speed in AM Super Shifter
Our team has come to the realization that we have absolutely no need for the second speed that is available in our AM Super Shifters. In the beginning of the season we thought we would be traversing the field multiple times leading us to chose the SS. However, at our first competition we maybe crossed the barrier two or three times and never went into high gear. We have also realized that our drive train may have been geared to high seeing as how are robot jumped more than turned. Ultimately we would like to remove the second stage of the super shift along with all other pneumatic related components to give us more weight to play with elsewhere on the robot. We have thought about changing gear boxes but out drive plates are designed around Super Shifters and the allocated 6 hours we have before Mount Olive would not allow us change this.
I have thought about this for a while and I think that if we just remove the gears and leave all the associated shafts we will be able to take out the pneumatics and achieve the desired results. Any clarification into this subject would be great.
Unread 13-03-2012, 12:46
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Removing High Speed in AM Super Shifter
You could use a retaining compound like loctite 680 and literally glue the dog gear and shaft in place.
To remove the gears you will need to replace them with some kind of spacer.
Unread 13-03-2012, 12:57
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
You could use the spring return cylinders, they hold u in low gear until air is applied to shift to high. They would hold you in low just fine with nothing hooked to them
You wouldn't loose the weight of the gears and cylinders, but the rest of the air system could go if you didn't need it.
2016 Central Illinois Winner. Curie Division finalist
Unread 13-03-2012, 12:58
Jared Russell's Avatar
Taking a year (mostly) off
In 2010 we turned an AM Shifter (Gen 1) into a single speed box simply by removing gears and locking the dog in place with a spacer.
Unread 13-03-2012, 13:05
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
This year we did the same, but with a Gen 2. However we never removed the high gears from the gearbox. We simply locked down the pin to low gear with New spacers and the pneumatic cylinder holding plate. All you have to do i bring new bolts and spacers to the competition. Remove all cylinders and pnuematics that are no long needed, and put new spacers in place and bolt them down. I'll try and find a picture or a CAD to show you.
EDIT: Here is a picture of the modification that maybe able to be used on a SuperShifter
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 14-03-2012, 08:23
JB's Avatar
JB JB is offline
AKA: Jon Bryant
FRC #0238
Thanks guys. I think were gonna attempt the spacer idea because we already use the spring return air cylinders and we just want to cut as much weight as possible. Removing the gears and all associated air is the main goal and we think the spacer is the best idea. Hopefully it will give us enough weight to change our arm
My posts are solely my own and do not necessarily reflect the views or opinions of FIRST® or my affiliated team.[/center]
FRC® Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 14-03-2012, 08:38
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I think you can also use a bolt and nuts to hold the "shift lever" to where you want it (similate the pneumatic in or out).
I think the fitting where the pneumatic connects is a 1/4-28, so use the right bolt!
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 14-03-2012, 09:07
FRC #1836 (MilkenKnights)
The low gear is really low - usually close to 5 - 7 fps. That is really slow.
Unread 14-03-2012, 09:47
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
If you have the money, why not look for a solid toughbox gear reduction you like for a quicker fix?
Unread 14-03-2012, 09:49
Andrew Lawrence
Posts: n/a
This. If you want a good, one speed gearbox, use Andymark's CIMple box that came in the kit. It's not only a good one speed, but it's also lighter than the AM SS, so you'll not only get your preferred speed, but loose robot weight in the process. It's a win-win scenario.
Unread 14-03-2012, 10:09
Final speed depends on your wheel size and any output ratio from chain/belts. In 2010 when we locked our 2 speed, we put it in high gear and increased the final chain reduction to obtain a speed of about 9 feet per second.
