Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Unread 13-03-2012, 15:44
Codec Codec is offline
Team 1418-Programming & Electronics
AKA: Shayne
FRC #1418 (FIRST Robotics Team 1418)
Codec is an unknown quantity at this point
Re: Digital Sidecar Problem
This is what I mean by "basic switch" I also tried twisting the wire together.
I am using the example Simple Digital Input vi
Front Panel:
Also, I was told that the 4-slot and 8-slot had the same amount of memory, I was wrong. My bad
Originally Posted by Dr. Fancypants View Post
We found that one side of our sidecar ribbon cable had become unclipped, causing sporadic communications issues. A quick squeeze in the vise got it working like new again. Might want to check that?
I checked the cable and the clips were fine. Thanks for the suggestions though
