Go to Post For a good time, call 1-800-GOFIRST - Wayne Doenges [more]
Unread 13-03-2012, 12:09
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Kinect usage at competitions
Is anyone here using the kinect at competitions? I wasn't too surprised to not see anyone use it at the week 1 event I worked at, but I figure that some teams would start using it by now. If you are do you mind sharing how you are using it?
I win! XD
Unread 13-03-2012, 12:22
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Kinect usage at competitions
I saw only one team using it at Lake Superior, but then I was only watching (from the floor) during our team's matches and some of elims.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 13-03-2012, 12:39
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
We used it at the Rutgers MAR event, I don't know if any other teams did. Didn't have to debate who got the station though
Unread 13-03-2012, 12:49
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
I attempted to help our team set it up to be used at Traverse City, however, and we were even given some time on the field during lunch to test it (because there were problems the first day with us using a USB hub, apparently that was not working with the extra cable length, we were unable to test during it on setup night) (I'd like to thank the field personnel for trying to accommodate us setting it up).
However, I was severely disappointed in how it functioned, and I can't say for sure if it was due to the setup at the field or just the Kinect in general, but this is what I was seeing:
Reliability: I was frequently seeing a loss of the control enable signal (button 9) which indicates that the users arms are in valid position (extended in the same xy plane). I am a bit suspicious that this could be due to cable length.
Sensitivity: The controls I had setup the robot to use (left/right leg forward/backward) seemed extremely sensitive, making them essentially impossible to control. Depending on the posture I stood with, I would see the buttons for leg forward/backward activating sporadically.
Speed: Our driver station (not a classmate, but it had an atom) was abysmal for controlling using the kinect, it was processing 4 or 5 FPS max. We had to setup my programming laptop to get decent results (which left me unable to make programming changes outside of extended periods of downtime) and was draining the battery much more quickly, so we eventually were going to need an external power supply installed on the field.
Height: I'm about 6' with long arms, and the Kinect was barely able to pickup my elbows while I stood in the box.
The above issues pretty much killed all excitement about using the Kinect for me. When you can't drive the robot correctly because control is constantly cutting out, and the robot is picking up different gestures based on you slightly changes in stance, and it's not picking up your full range of motion...
I wanted to try out using different gestures for control (legs and head to the sides instead of legs forward/back, along with some logic to continue the last input when the control enable signal vanishes), but if that doesn't work I feel I will need to recompile the KinectServer in order to get it to be less sensitive.
All of this combined with the fact that we were doing really well in standard autonomous, kinda made me think it wasn't really worth fussing with anymore.
I'm hoping to do some off season projects with it once we can permanently unbag the robot, but until then there are lots more things to worry about.
Unread 13-03-2012, 13:52
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
We will be using it at the Los Angeles regional this weekend, mostly to delay/activate our launcher to ensure we deconflict with other teammate's autonomous modes. I saw too many shots miss in Week 1 because 2 balls were trying to enter the 3-point target at the same time.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 13-03-2012, 16:48
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Team 1912 Combustion will be using it at the Bayou Regional this week. Hopefully it works..
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 13-03-2012, 16:57
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
A couple of teams at Alamo and a couple of teams at FLR. All it's really good for is taking up floor space.
It's a joke.
Unread 13-03-2012, 17:02
LondonBoy29's Avatar
LondonBoy29 LondonBoy29 is offline
A Man 3000 Miles away from his team
FRC #1884
LondonBoy29 is on a distinguished road
Team 23 used the kinect at the WPI regional. I believe it was used to tip the bridge.
Unread 13-03-2012, 17:06
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
It's a novel implement and does have some legitimate uses (see HOTs recent technical design whitepaper) but using it for main control in Hybrid mode is hardly better/more reproducible than a sheer open-loop implementation in all but the simplest of autonomous routines.
We might play with it a bit offseason in case it is legal for use again, perhaps to use it in a way similar to HOT.
Unread 13-03-2012, 17:10
Undertones's Avatar
Undertones Undertones is offline
Drive Coach
AKA: Mac
FRC #4334 (ATA)
Undertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond repute
Only saw one team using it at ON GTR East Regional, and that was only for one round. It kind of didn't seem to do anything.
I'm thinking someone should just like breakdance in the Kinect Station. You'd get massive street cred.
Team 4334, Alberta Tech Alliance, Calgary Alberta
Western Canada 2016 Champions
Western Canada 2016 Creativity Award
Utah 2016 Champions
Utah 2016 Excellence in Engineering Award
Western Canada 2015 Innovation in Control Award
Utah 2015 Champions
Western Canada 2014 Regional Chairman's Award
Western Canada 2014 Champions
Utah 2014 Judge's Award
Western Canada 2013 Champions
Western Canada 2013 Innovation in Control Award
IRI 2012 Champions
Archimedes 2012 Champions - "The Eh Team"
GTR East 2012 Highest-Seeded Rookie
GTR East 2012 Cooperition Award
GTR East 2012 Rookie All-Star
Unread 13-03-2012, 17:11
AKA: Josh P.
We joked around about having our human player go in and pretend to shoot baskets while the robot ran autonomous, but decided we didn't want to accidentally misrepresent ourselves to the judges
Unread 13-03-2012, 17:15
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
When I saw the teams using the Kinect I couldn't tell if they were doing anything effective. You might as well clown around with it.
Unread 13-03-2012, 18:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I've only seen a team use it once every 3-5 matches on the webfeeds I've been watching.
Unread 13-03-2012, 19:49
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
We gave serious thought to juggling balls. But then figured that the balls would be ruled illegal.
Unread 13-03-2012, 19:54
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Yeah refs are trained to not have a sense of humor about things like that.
