Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 01-03-2012, 11:58
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Re: FRC2016 Mighty Monkey Wrenches 2012 Robot Video
Love the robot and the music.
My question is why do you have the camera if your shooter does not turret. Does it judge distance or alignment or both? Or perhaps something else?
Also I love the 6 motor drive train...got to see what it could do at ramp riot this year and needless to say I think I will push for it next year.
Unread 01-03-2012, 13:20
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
need for the camera is distance and alignment... the camera has some other tricks attached to help make this easier.. our turret is our base, it gives us good enough alignment that we dont need a turret, but that alignment is entirely dependant on camera feedback.
Also the distance returned by camera determines shooter speed on a PID loop..
Originally Posted by Hallry View Post
Ah, the legendary ball return penalty of the 2010 NJ Regional
... the deserving alliance still won the event, it was great competition though. we really did enjoy playing the underdog role.
Team 56 2000-2007 (Student/Vol.)
Team 2016 2008 - ??? (Mentor)
Unread 01-03-2012, 15:46
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
You have a beautiful robot but unfortunately I have to be the bearer of bad news. The GDC has ruled that splitting numbers on bumpers is not legal thus you may not have the "20" on the left and "16" on the right of your gap.
Q&A:
Q. I have 1528 on the back and the two sides of our robot. If I put 15 on the front right bumper and 28 on the front left bumper, then I create our team number 1528. The number would therfore be in only one location (the front). Would this not satisfy the rule of having our number in only 4 location? FRC1528 2012-02-24
A. Per [R35], team numbers must be clearly visible. This means that they may not be inverted, obscured, fragmented, upside down, etc.
I am an LRI and we have discussed this issue at length and have been given no flexability in enforcing this rule. If you actually bagged your robot with split numbers on your robot you need to be preparing yourself to fix it at competition. I am not trying to "call you out", quite simply your robot is a perfect example of an issue that I fear is going to be more common than the GDC is aware. This is directed toward ALL teams, not just you guys. If you split your team number the GDC has determined it to be illegal and LRIs have been instructed to have teams fix the issue at competition. The GDCs logic is that a ref could quickly look at a robot with split numbers and assign a penalty to the wrong team in "real time".
I think it stinks but that's what the GDC has decided so we all have to live with it. Personally, I believe there is a "double standard" in the definition of a Bumper. We are told that a Bumper includes all parts (plywood, pool noodle, and fabric) thus the 8" minimum from the exterior vertex must include the plywood, however, 4 digit teams are also being required to fit a 4" x 3/4" stroke number into the same 8" space that lower numbered teams are and still make it "clearly visable". My reading of rule R35 says that the numbers must be on the Bumper (which by definition includes the plywood, pool noodles, and fabric) thus the numbers are to be placed only over the sections of the bumpers where the plywood is. LRIs have been told that team numbers can "spill over" into the soft only parts in the corner thus allowing a little more room for spacing the numbers apart. This seems like a "double standard" in the definition of a Bumper and a competitive advantage to lower numbered teams to me.
Back to 2016's robot: I'm not sure if you bagged with the numbers split as in the photo or all on one side like the video (maybe a practice bot?) but either way you guys have a beautiful machine that looks like it will be quite effective! Great job!
Unread 01-03-2012, 15:55
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Q&A:
Originally Posted by Lowfategg View Post
(Btw: If you watch the video, we fixed the bumpers.)
This is from the very first post in this thread.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 01-03-2012, 16:01
Yeah, saw that after I posted but like I said I'm not trying to "call them out" . Just pointing to their picture as something a fear a lot of teams might have done that they are going to be required to fix at competition.
Unread 13-03-2012, 22:28
deshnik deshnik is offline
AKA: Nikhil
FRC #0781 (Kinetic Knights)
Team Role: Student
deshnik is on a distinguished road
That's going to be hard on your team and drivers having 3 back to back regionals.we did that last year lot of people got sick.
after those 3 weeks could even remember anything, they all blured together as 1 long regional.
thats why this year we going to week 2,4,6 regionals.
