Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 06-01-2003, 21:24
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Exclamation How to build an Autonomous Mode dongle
I imagine there are some of you out there who will be interested in this information. We have determined how to build a dongle that plugs into the competition port and allows you to enable/disable autonomous mode.
The circuit above will give you a switch that has 3 positions: Robot Disabled, Normal, and Autonomous mode.
Disclaimer: you probably shouldn't build this. It could void the warranty on your control system. If you don't do it right it probably will ruin your OI. Please don't try it if you don't know exactly what you're doing.
Unread 06-01-2003, 22:56
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Re: How to build an Autonomous Mode dongle
http://www2.wildstang.org/phpBB/download.php?id=15
Is it that different from the competition disable dongle posted here on CD? Why the huge risk?
Unread 07-01-2003, 00:09
Software Engineer
Rookie Year: 1995
Re: Re: How to build an Autonomous Mode dongle
It's exactly the same as the disable dongle. Pin 6 gets grounded for Disabled mode, pin 5 gets grounded for Autonomous mode. The risk isn't that great, but since this information hasn't been published by Innovation FIRST it's worth pointing out that it might void the warranty. And, I don't want someone to try it and screw it up and say "I did what you said and it screwed up the OI!" If you feel comfortable building the disable dongle, you should be able to build this without a problem.
Unread 07-01-2003, 04:56
Exclamation Pin 12 ground - NOT GOOD !
!!!!! W A R N I N G !!!!!
When I made a remote dongle for a competition clock, I asked IFI if i t would be correct to connect the port in a similar fashion, and was warned not to use 12 as ground, as it was to be reserved for some future use. IFI said the 2002 manual had not been updated before publishing, in this content area.
I posted this last year, too.
Unread 07-01-2003, 09:17
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Does anyone know of an alternate ground pin? Also, can you use this dongle to change channels, too?
Jeff Waegelin
Unread 07-01-2003, 09:21
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
You change the channels on the Operator Interface itself. I believe it's the switch set on the bottom that has more switchlike qualities (I don't thing you need a pen to change it). You have to use the Yellow Dongle in the whitepapers section to be able to use multiple channels.
Unread 07-01-2003, 09:32
Software Engineer
Rookie Year: 1995
Yes, this dongle should behave the same as the yellow dongle with regards to using other channels.
Unread 07-01-2003, 09:40
Software Engineer
Rookie Year: 1995
Re: Pin 12 ground - NOT GOOD !
This dongle (and the yellow dongle) isn't using pin 12 as ground. We're using pin 8 as a ground. Pin 12 is being pulled to ground by pin 8, and pin 5 and 6 are being pulled to ground by pin 8 when the appropriate side of the switch is closed. This is still how it's described in the 2003 OI Reference. Do you think that the 2003 OI Reference is also incorrect?
Unread 08-01-2003, 09:25
FRC Key Volunteer Trainer
AKA: CrazyNate
FYI, Innovation First has now posted an official schematic for a Dongle which supports channel select, disable switching, and autonomous switching...here's the PDF...
http://www.innovationfirst.com/FIRST...nout_Guide.PDF
Nate Smith
nsmith@smythsoft.com
Unread 11-01-2003, 13:09
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
If pin 8 is ground why does IFI connect that pin to an external ground in their diagram?
Unread 11-01-2003, 20:52
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
I figure that if that schematic is wrong...then innovation first will have to take some kind of responsibility for everyone zapping their operator interface.
We finaly got ours finished tonight but we haven't tried it out yet.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 12-01-2003, 20:56
Re: Re: Pin 12 ground - NOT GOOD !
Since pin 12 and pin 15 were connected, originally, for channel access, I must have mixed them. The original 2000 Docs call for ground on 15 and 8 (the two end pins on the connector, but 15 is no longer to be used as ground.
I've had a match timer that disables controllers and allows channel selection since last year, and pin 8 is the sole ground used.
Unread 13-01-2003, 00:11
Software Engineer
Rookie Year: 1995
Re: Re: Re: Pin 12 ground - NOT GOOD !
Ah, that makes sense. You had me worried there for a minute that I was unintentionally spreading bad information...
Unread 13-01-2003, 00:15
Umm Errr...
I plan to build a big red E-spot button into my "dongle" Just incase something goes awry during testing of our robot.
1139 Alumni
Unread 13-01-2003, 09:19
El Jefe de 148
We built a dongle using your design this weekend, and it's working perfectly. Just make sure you know which part of your switch is the common. It took us a while to figure that out, and re-soldering connections is not fun.
Jeff Waegelin
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
