Go to Post Checklist: Robot on, thinkamajig set, autonomous set, safety bar pulled. - DonRotolo [more]
Unread 13-03-2012, 22:52
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Flywheels and Shooter Wheels
Our robot uses a single-wheel shooter on a rotating turret. (Actually, it's two wheels close together on one axle, so they act as one wheel for purposes of this discussion.) We're considering adding a flywheel, because it is supposed to help with consistency, given the different ways balls react to the shooter (older balls get softer, so they don't shoot quite as far for the same settings). At least, that's what we've been told.
My question is, has anyone done a test to demonstrate that the flywheel helps, and by how much? How big a flywheel is needed? I enjoy trying new things, but at this point in the season (our second regional is a little over a week away) I don't want to have my team spend a lot of time and resources for something that may be of no value. Possibly it could do more harm than good (causing vibrations, increasing spin-up time, adding weight high on the robot...). But if I saw evidence that it really helps, we could be convinced to give it a go.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 13-03-2012, 23:29
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Flywheels and Shooter Wheels
We decided against a flywheel, because we found that the mass slowed our ability to get back up to speed after a shot. Instead we use a tightly-controlled PID loop with 'normal' speed at about 70% power. The extra 30% "headroom" allows up to spool the wheel back to speed in about 1.6 seconds at present, but we are working to improve the response time.
One difference to your wheel is that we use two powered wheels opposing each other, allowing us to more closely control backspin.
Unread 14-03-2012, 02:29
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
A flywheel will allow for tuning your pid more easily. The increased inertia will help damp acceleration and deceleration.
However, consider it as a physics problem.
From a standstill, you need to spin that flywheel up to a given RPM. The heavier the flywheel, the more work it will take, and the longer it will take.
Once you have fired a ball, a given amount of energy is transferred from the flywheel to the ball. Regardless of whether your shooter slows down a little (heavy shooter) or a lot (light shooter), you'll need to use your motors to add that same amount of energy back into the system. The same amount of energy is removed from both systems, so the motors will have to work just as much in either case to add it back in.
The sum effect is that unless you make your flywheel so heavy that you can shoot without having to spin it back up, a flywheel will only slow down your shooting, due to a longer initial spin up time. It may make it easier to tune a PID to control your shooter. We use 8 inch wheels and have managed to tune a fairly accurate pid (+/- 6% speed).
Unread 14-03-2012, 08:05
AKA: Gerry
I think a shooter with a flywheel can transfer a little more energy than without a flywheel. I am assuming that the rate of energy transfer is proportional to the difference between wheel speed and ball speed. Imagine two identical shooters A and B, except that shooter B has a flywheel. Shooter A will slow down during the launch process, so it will be adding less energy near the end of the launch. Shooter B will maintain its speed (nearly), so it continues adding energy to the ball at a higher rate than A.
What I don't know is, does the flywheel help the launcher behave more consistently with balls of different stiffness? "Consistent" meaning balls exiting the launcher at the same speed, regardless of stiffness.
Cal
Fairport, NY, USA
Unread 14-03-2012, 11:16
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Hello, some of this is slightly off topic but I do have a reason behind it.
During the build season Team 1100 had a huge consistency issue with our basketballs. four out of our five were relatively normal (and behave how the competition balls behaved at WPI regional), but one was especially hard and dense. we had originality built an opposing wheel shooter that was powered by an FP motor on each wheel with a 4:1 reduction using KOP wheels. After testing we where not able to control the speed of the shooter reliably enough to score any balls consistently. We decided to switch to a single wheel shooter with both of the FP motors running on direct drive. The new shooter was capable of shooting 3 pointers from the key according to the math but wasn't meeting that in real life so we had a slight problem. To fix the problem we added two steel flywheels inside our shooter wheel (a 2.3" OD PVC pipe) each one is about a pound and has an OD of ~2 inches. and increased the compression of the ball by moving the back plate in, causing more energy to be put into the ball.
With these modifications we noticed a few changes:
  1. More consistency at all speeds, regardless of ball properties
  2. Better control of the ball, especially at low speeds
  3. Greater top-end range
  4. Less effect on our shooter' surface velocity while we were shooting
It should be noted that the only way we could increase the compression was to add the flywheel because the shooter bogged down to much without it.
At the WPI regional we decided to forgo shooting from the key because it was much more consistent to have our operator aim from the fender instead and we didn't fully have the control algorithm for our turret's tilt mechanism up and running. That said, 1100 was the first seed at the regional and only missed 5 balls all competition wile running in AUTO mode. Two of which were due to positioning the robot in the wrong spot to accommodate an alliance partner.
At Boston we intend to run the same auto-mode but shoot 3s from the key.
I hope this helps,
-Dan
Unread 14-03-2012, 11:20
Chris86 Chris86 is offline
FRC #4064 (Inzombiacs)
Chris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to beholdChris86 is a splendid one to behold
We didn't actually test out flywheels on my team, but I would think that flywheels would improve consistency. One of the problems with stiffer balls is that they require more energy to compress and thus slow down your shooter much more - taking energy that is not really going towards speeding up the ball. Flywheels, as was said previously, cause your shooter to maintain its speed better when it is transferring its energy to a ball. By maintaining wheel speed, you ensure that "stiffer" and "squishier" balls exit closer to the same speed.
That being said, sizes and weights of flywheels for this purpose would require testing and data. Soooo I guess you either need to try out some flywheels yourself or hope that somebody comes along with the data instead of using general conceptual analysis of the problem.
Current mentor for Team #4064
Proud former member of Team #86: Team Resistance 2007-2011
Unread 14-03-2012, 11:29
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Our shooter, as designed and built, included an aluminum flywheel between the two shooter wheels, on the same rotation axis. Preliminary testing showed all the benefits you would expect, consistent shots and nearly no RPM dip between shots. And, yes, the PID control over the wheel RPM was much smoother. Surprisingly, the flywheel did not make such a difference in the spinup time, as we have plenty of excess shooter drive motor power. As the electronics were installed, it became evident we had a serious weight issue, and the flywheel had to go.
We have solved our weight issues (shortening the tower helped) and now probably have the spare weight to reinstall the flywheel. But, with the importance of bridge balancing, we may not be willing to add back 2 lbs to the top of the tower. That weight may be better spent on adding a "killer bees" style balance steadying stinger. We'll see how our first competition goes this weekend.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 14-03-2012, 12:12
AKA: Gerry
Thanks for these responses, everyone. This discussion is really helping.
Several people have mentioned PID control. Are you using the Jaguar built-in PID feature, or are you implementing it yourself in the cRIO? Either way, what's your tuning method, and how long did it take? We only have the Thursday at regional competition to get it done.
Cal
Fairport, NY, USA
Unread 14-03-2012, 12:19
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
I am confused as to what the difference is between a fly wheel and a shooter wheel??
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 14-03-2012, 12:21
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Yes I am also interested in how you guys do PID looping. A code snippet anyone?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 14-03-2012, 12:24
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
The shooter wheel is an object that propels the ball from the robot. it may have some inertia but usually doesn't have very much.
A flywheel is a device thats only purpose is to store rotary inertia. It is usually heavy and has most of it's weight as far away from the center shaft as possible to maximize the inertia to weight ratio. Ideally the flywheel would be direct drive from the motor where the shooter wheel would be through some gear reduction.
On many teams these two objects are the same.
On an unrelated note, 1100 didn't need to use a PID control to get consistency in our shooter, just standard PWM drive through a jag.
Unread 14-03-2012, 12:54
This wouldn't be very ideal (or safe) on a 19,000 rpm motor like the 550.
Unread 14-03-2012, 12:55
AKA: Gerry
That's not "unrelated"; it's very relevant, as implementing a PID within the limited timeframe is one of my big concerns at this moment. If we can just use open-loop control and still get (most of) the benefit, we are more likely to go for it.
Cal
Fairport, NY, USA
Unread 14-03-2012, 13:00
You didn't mention in this thread what motor controller you are using. If you are using a Jag via CAN, at least consider using Voltage mode instead of %Vbus. This will compensate for varying supply voltage.
Unread 14-03-2012, 13:29
You can also do similar compensation in the cRIO by scaling your command based on the battery voltage. A member of team 1986 outlined their specific method of doing so in one of these PID/shooter threads somewhere.
