Go to Post Dean looks rather debonaire in a tux. Like some sort of engineer super hero. The tuxedo is like his Clark Kent costume under which lies his amazing denim suit, to be whipped out at a moments notice in the face of uninspired youth and problems unconquered. - phrontist [more]
  #31   Spotlight this post!
Unread 14-03-2012, 13:06
Re: Cim-Sim gearbox for shooter questions
Originally Posted by Dan_Karol View Post
it appears I hit the wrong button
Ah. In each post, there's an icon in the lower right corner that says "quote". Click on that and it will automatically provide context (which you can redact as desired) and link your response to that post.
  #32   Spotlight this post!
Unread 14-03-2012, 22:57
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Yes.
2.7 speed reduction on a 19300 rpm motor driving 8" wheels => high torque on pinion.
How much engagement was left of the pinion into the first-stage gear in the CIM-U-LATOR with those spacers?
The gear overlap was still >80% since we pressed the pinion on less far down the shaft to anticipate this. I was kind of suspecting over-torque was the culprit. We have the option to do a 2:1 further reduction by going 15 to 30 with the belt pulley pair, but will even this be enough? We could also add a flywheel to reduce the level of braking torque that the squished ball effect applies to the motors. We can also add a 2nd gearbox driving the other side of the wheel shaft to divide the torque loading that the motors see a factor of two.
Any suggestions on what order woulf be best for trying these options?
-Dick Ledford
  #33   Spotlight this post!
Unread 14-03-2012, 23:17
The cantilevered pinion would contribute somewhat to the stresses on the motor bearing.
Did you consider milling cooling grooves in the CIM-U-LATOR instead of using spacers?
http://www.chiefdelphi.com/forums/sh....php?p=1120101
  #34   Spotlight this post!
Unread 15-03-2012, 13:38
Mr.Savagness Mr.Savagness is offline
FRC #1178
Mr.Savagness is an unknown quantity at this point
Originally Posted by Chris Fultz View Post
We have a similar set=up, except we are pulling the ball from the bottom and shooting over the top.
We are using 2 CIM-sim's on our shooter. 2 FP and 2 AM motors total.
We are direct driving the wheel, so there is no speed reduction from the gearbox output.
We are running 2 8" AM hard plastic wheels, spaced about 2" apart. All is assembled as a single unit so all motors, gearboxes and wheels are linked with a single shaft.
We have about 2" of squeeze on the balls.
For shooting from the top of the key, i think we are running about 55% speed. Using Victors.
Isn't that a bit of an overkill? We are using 1 cim-u-lator with 1 banesbot motor and with only using a little under 70% power we are shooting around 52 feet.
Last edited by Mr.Savagness : 15-03-2012 at 13:41. Reason: using cim-u-lator not a cim
  #35   Spotlight this post!
Unread 19-03-2012, 01:49
AKA: Dick Ledford
Yes, I just got the 9mm ball end mill to di this, but meanwhile we switched over to using the single motor version of the CIM-U-lator with the 18V 775 motor.
Distance is not quite as good, but it seems to bedoing better at handling force on the pinion bearing end of the motor. We can also boost RPM 7% by going from 30-to-30 with the belt pulleys to 30-to-28.
Thanks.
-Dick Ledford
