Go to Post We all change, and we need to make sure that we can grow and change together in a positive way. Keep close the people who are capable of doing this with you, and you will surround yourself with the tools for success. - Jaine Perotti [more]
Unread 14-03-2012, 13:29
Re: Flywheels and Shooter Wheels
You didn't mention in this thread what motor controller you are using. If you are using a Jag via CAN, at least consider using Voltage mode instead of %Vbus. This will compensate for varying supply voltage.
You can also do similar compensation in the cRIO by scaling your command based on the battery voltage. A member of team 1986 outlined their specific method of doing so in one of these PID/shooter threads somewhere.
