Go to Post Limits are imposed by both man and nature. Understanding those limits and attempting to push past them is the basis of creativity. - Dave.Norton [more]
Unread 14-03-2012, 12:21
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
[DFTF] Camera as Remote Eyes...
This is part of a series of posts called Drinking From The Firehose on getting Dr Joe back up to speed on All Things FIRST.
Today's topic:
Using the Camera to provide a remote set of eyes...
Using the camera to auto aim is just not in the cards for Schodinger's Cat this year (read [DFTF] The Classic Blunder... to learn that our robot, The Rook, is lucky to have a ball handler at all).
BUT... ...we may be able to manage mounting the kit camera on The Rook's beefy arm to
  • help us see if we are lined up with the basket or
  • see if a ball is lurking twixted The Rook and the dark side of a bridge or
  • get a close up view of the sweat beading up on the foreheads of our opponents ;-)
Frankly, I am scared to death to do it. Not that it wouldn't be helpful but that it will screw something else up in the process (Why won't our robot respond Scottie? It's that video feed, Capt., it's eating our bandwidth like I eat haggis on Burns Night ... ;-)
So... ...tell me all. Can we safely use the Kit Camera as a remote set of eyes for our drivers?
And be quick about it. We've got BU in 7 days.
Joe J.
Team #88, TJ2
Unread 14-03-2012, 12:33
Re: [DFTF] Camera as Remote Eyes...
Yes. Just configure the camera for your team's address, mount it (keep it electrically isolated from the robot frame) give it 5V power, and plug its network connection in to the DAP. It's that easy.
Unread 14-03-2012, 12:35
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We started the season working on auto aiming for the camera and got it to work well but in the two weeks of practice we have found that our driver can aim using the camera much faster and just as accurately as the auto function.
We commented out all of the auto aiming code.
I have spoken with another team with much more programming resources than ours and they have discovered the same thing.
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
At GSR there were several teams that switched from an aiming camera to a "second set of eyes" camera. We plan on adding one for Championship.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 14-03-2012, 13:43
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Hit the nail on the head. We are using 2 camera's, one for alignment for our shooter and another for our ball intake/bridge pusher. We power both off the 5V Wago supply using a terminal strip.
We have had no problems with lag/dropped packets or any other communication issues, I believe our video resolution on each camera is set to 640x480 in the camera f/w. The default dashboard works fine for 1 camera. Since we use 2 camera's we modified our dashboard (along with some other info). Here is a link to our Google Code repository, which includes the Dashboard project
>2012 Game Robot>Program>Dashboard
Unread 14-03-2012, 13:52
Last year, our classmate couldn't display images at 320x240 30fps without pegging the classmate processor and causing occasional control lag. We changed it to 10fps and it worked well. I saw several people saying they did the same thing this year.
If you are using another driver station computer, that shouldn't be an issue.
Unread 14-03-2012, 13:58
DavidGitz's Avatar
Originally Posted by Joe Ross View Post
Last year, our classmate couldn't display images at 30fps without pegging the classmate processor and causing occasional control lag. We changed it to 10fps and it worked well. I saw several people saying they did the same thing this year.
Right, same here, forgot to mention it. We are using a newer laptop with 4 GB RAM, 17"? screen and running Windows 7. We needed the screen size for both cameras, plus the Kinect software was super slow running on our original Classmate.
Unread 14-03-2012, 14:01
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
If your concerned about bandwidth, you can fairly easily reduce the framerate and resolution of the camera.
We're using a netbook about the equivalent to the classmate and it works fine at 320x240 10fps (IIRC).
Regarding the auto aim, I was amazed to see how well our drivers were able to line up manually (we had some issues with our wifi bridge yesterday, so thats all we had). For our autoaim, I included a safeguard that prevented the operator from firing until we had a lock OR until he pressed a second button (as an override). We still have all our camera code in, but it's barely been used.
Unread 15-03-2012, 12:48
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
15 FPS is good @ 320*240 on the wee DS, really no lag whatsoever. Kinect is a diff story/problem/solution that doesn't belong here.
Just verify which camera you are using, the old 206 needs some monkeying w/ Dashboard AND Robot code that is automatically configured for the newer 1011.
As for mounting, make sure it is on something that is strong but gives just a little. IE 2405 (that's us!) good piece of thick plexi (not thin lexan) running across front of our boxy frame, with a tapped hole in the middle for the screw on the back of the camera. Screw it on, connect wires, check lens focus on it. If neccessary, tape down the spinny thing if the vibrations from the shoooter are so violent that the drivers are "flying blind" after Auto.
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
